Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Renaming sketch variable (by selecting them from the sketch)
2 REPLIES 2
RoyWickrama_RWEI
465 Views, 2 Replies
With I started to doing with iLogic, I keep getting more and more problems (or needs). To go through my modelling at hand, I need to rename sketch variables as they need. Using an ilogic, is there a way to pick these required variables from the sketch and then to rename (in a text box available) one by one?
Please help. Thanks
2 REPLIES 2
rjay75
in reply to: RoyWickrama_RWEI
This will rename a sketch dimension.
1. Select the dimension.
2. Run the rule
Rule Code:
Dim oSelect As SelectSet
oSelect = ThisApplication.ActiveDocument.SelectSet
If oSelect.Count = 1 Then
    sd = oSelect(1)
    If TypeOf sd Is DimensionConstraint Then
        newName = InputBox("Enter New Name:", "Rename Dimension", sd.Parameter.Name).Trim()
        If Not String.IsNullOrEmpty(newName) Then
            sd.Parameter.Name = newName
RoyWickrama_RWEI
in reply to: rjay75
I am sorry: I missed to accept this as solution before!
