With I started to doing with iLogic, I keep getting more and more problems (or needs). To go through my modelling at hand, I need to rename sketch variables as they need. Using an ilogic, is there a way to pick these required variables from the sketch and then to rename (in a text box available) one by one?
Please help. Thanks
Solved by rjay75. Go to Solution.
This will rename a sketch dimension.
1. Select the dimension.
2. Run the rule
Rule Code:
Dim oSelect As SelectSet oSelect = ThisApplication.ActiveDocument.SelectSet If oSelect.Count = 1 Then sd = oSelect(1) If TypeOf sd Is DimensionConstraint Then newName = InputBox("Enter New Name:", "Rename Dimension", sd.Parameter.Name).Trim() If Not String.IsNullOrEmpty(newName) Then sd.Parameter.Name = newName End If End If End If
