Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Renaming an extrusion feature
2 REPLIES 2
oransen
1109 Views, 2 Replies
The following code crashes with an exception at the point where I try to rename the extrusion feature:
    CComPtr<ExtrudeDefinition> pExtrudeDef;
    hRes = pListOfExtrusions->CreateExtrudeDefinition(pProfile,kCutOperation,&pExtrudeDef);
    pExtrudeDef->SetDistanceExtent(_variant_t(kHeight),kSymmetricExtentDirection);
    // Add the extrusion.
    CComPtr<ExtrudeFeature> pExtrude;
    hRes = pListOfExtrusions->Add (pExtrudeDef,&pExtrude);
    if (FAILED(hRes) || (pExtrude == nullptr)) {
        return ReturnAndShowCOMError (hRes,L"ExtrudeSketch but could Add ExtrudeDefinition\n");
    // Crashes here. All is fine if I don't rename the feature with this call...
    pExtrude->Name = L"EXTRUDED_CIRCLE" ;
The crash seems to happen inside ExtrudeFeature::PutName.
Is it possible to rename an extrusion feature. If so what is the method to do it?
2 REPLIES 2
oransen
in reply to: oransen
As usual as soon as I post I find the asswer. I should have been using put_Name, not Name, I believe.
Tags (1)
jdkriek
lol Indeed, and yes that's correct.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
