I would like to run a ilogic rule in any assembly environment so that it has to allow me to rename components in series say "A01, A02....or PJ12, PJ13 or in any series ".
I had tried the code, please refer to the attachment, this code worked well, it had renamed all the components in assembly environment.
But when I open the part file in a separate window, the component name is reverted back to original one before applying the iLogic code mentioned in the attachement.
Please let me know how to fix this.
Mahesh
Browser nodes are unique names that the assembly gives to it's components (a nick name).
It's only used in the assembly browser and it can be modified in the iproperties occurrence name as well but it doesn't exist in the part as far as I am aware.
I use the occurrence or browser name to asign project specific information to that part like valve or instrumentation tag number. The part and assembly node is not the same aniway, the part ussually has the filename and the assembly has the "part number:#(instance number)".
Why do you need to change the part browser name? I understand needing to change the assembly browser name but not sure about part?
Thanks for your mail. One of our customer created a sample assembly file with different configurations.
Customer expectation:
Let us say, If we change the configuration of assembly to small, medium or large, respective configuration would get updated, at the same time all sub-assemblies and corresponding part files has to be renamed, say PRT001, PRT002 and so on or in any incremental fashion.
Purpose:
To maintain unique part numbers for different configurations.
Please let me know how to do the same.
Hi Manesh,
This sure looks like a job I would do with iassemblies. Have you considered that?
With i-assemblies, we have to create different configurations by inserting several rows and columns and changing corresponding values and it's a time consuming process.
As we know that, with i-Logic, we can establish logical connection between parts, sub assemblies, so that we can create different configurations by varying several parameters.
So, I would like to know, is there any possibility, we can change the names of part, sub assembly with ilogic.
Please let me know.
I am guessing you wan to change part number, and filename based on the chosen configuration (large, small, etc.)
There are ways of renaming the files and part number but can I ask you a couple of more questions? I don't want to waste your time just trying to understand your needs.
Will this be located in a library folder, reused in different projects?
Do you want to use this as a template so the user chooses the configuration and then the code creates a local copy of the files with proper name and part number?
To shortly answer you question, you need to look into copying the files with a new part number and filename, replace the assembly old file with the new one, delete the old one from disk.
I am very much obliged to answer your questions.
Please find below mentioned answers for your questions.
These files would be located in library folder, since these part files are specific to particular project, so there is no necessity for reusing it.
We are not using any specific template for proper name and part number.
We are entering the name according to the standards of our company.
We want to make utilize of template.
Yes, but old one must retained on disk and new one have to copy in the new folder location, we are doing it manually using "i-Logic design copy".
I would like to know about my query.
Please help me on same.
Look forward for your valuable reply.
I didn't got that message just the second one. Let me get back to you when I get some time.
I’ve been looking all weekend at this thinking for a solution.
We have deviated quite a bit from the original question so to solve that first I have found that you can change the part browser name and if done from the assembly it will change the assembly browser name too as long as it’s not been forced overwrite in the assembly. You seem to rename the browser nodes at the assembly level so you might need to clear them out before running it at part level.
At drawing level you need to replace the name with space (use space bar) and at part and assemblies you just need to delete it to reset it. Try renaming it with “” (nothing) and see if that does it.
Brinan’s code bellow will do the changes in the part level and assembly updates as well but you need to clear the occurrence override at assembly level as above.
For the second part of this thread unfortunately I don’t have a solution. We have an addon that clones our assemblies and it allows us to specify new names for parts and it keeps references between part, asm, idw but I can’t see how that addon was made (code I mean).
Like I told you it needs to be done in separate steps.
I am sorry I don’t have more info and can’t help you more, maybe you need to post this questions again not mentioning the browser name (you’re not really after that).
I have this code that does a "SaveAS" on all the parts in the browser. It sounds like it is what you want to do.
The code looks more complicated than it really is because it derives the part number from the assembly name and decides the numbering order of the parts based on the part size.
Have a look and see if it helps you
SyntaxEditor Code Snippet
Sub Main Dim oDoc As AssemblyDocument = ThisDoc.Document Dim AllDocs As DocumentsEnumerator = oDoc.AllReferencedDocuments Dim refDoc As Document Dim FileCount As Double = 0 Dim PartRangeBox As Inventor.Box = Nothing Dim PartDoc As PartDocument Dim PartComDef As PartComponentDefinition Dim DictionaryOfVolumes As New SortedDictionary(Of Double, PartDocument) Dim RangeBoxVol As Double = 0 Dim ArrayX As String Dim DicText As String Dim DocDoc As PartDocument Dim sPath As String Dim RenameCount As Double = 0 Dim oDetail As String = 0 Dim oDetails As Double = 0 Dim oDetailCount As String = 0 Dim NewPartNum As String Dim DeleteFile As String 'Check this is an assembly If oDoc.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule can only be run in an assembly document!", "TKSY", _ MessageBoxButtons.Ok,MessageBoxIcon.Exclamation, _ MessageBoxDefaultButton.Button1) Return End If sPath=Left(oDoc.FullFileName, (Len(oDoc.FullFileName)-Len(oDoc.DisplayName))) sPath = sPath.ToUpper 'MsgBox(sPath) For Each RefDoc In AllDocs PartDoc = RefDoc PartComDef = PartDoc.ComponentDefinition FileCount=AllDocs.Count 'MsgBox(FileCount) 'Call Function to get the rangebox PartRangeBox = RangeBoxFunction(PartComDef) 'Get Range Box Volume RangeBoxVol = GetRangeBoxVolume (PartRangeBox) 'Check if part with same volume already exists in dictionary Do While DictionaryOfVolumes.ContainsKey(RangeBoxVol) RangeBoxVol = RangeBoxVol + 0.001 Loop 'Check File Path and Only add Parts in same directory to dictionary Dim CheckPath As String CheckPath = Left(refDoc.FullFileName, (Len(refDoc.FullFileName)-Len(refDoc.DisplayName))) CheckPath = CheckPath.ToUpper 'MsgBox(CheckPath) If CheckPath = sPath Then 'Add Volume as Key and Document as the value of our dictionary DictionaryOfVolumes.Add(RangeBoxVol, PartDoc) ArrayX = ArrayX & RangeBoxVol.ToString("0.00")+vbCrLf Else 'Do Nothing End If Next 'MsgBox(ArrayX) 'Get a count of Parts That Need renaming RenameCount = DictionaryOfVolumes.Count + 1 'MsgBox(RenameCount) 'Rename Parts Loop For Each VolumeAndDoc As KeyValuePair(Of Double, PartDocument) In DictionaryOfVolumes 'Get the Part Document From Dictionary DocDoc = VolumeAndDoc.Value ' Dim DocString As String = DocDoc.DisplayName' ' MsgBox(DocString) oDetailCount = oDetailCount + 1 'List Item Number 'This line reverse the numbering system; last item in list (Largets Part) becomes item 1 oDetails = RenameCount - oDetailCount 'Add the leading Zero oDetail=Microsoft.VisualBasic.Strings.Format(oDetails,"0#") 'MsgBox(oDetail) 'Make a new Part Number to TKSY Standard NewPartNum = Left(oDoc.DisplayName, 12) & oDetail & Left((Right(oDoc.DisplayName, 7)), 3) 'Put the new part number into iProperties DocDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value=NewPartNum Try 'And save the file as (You'll get an error if the file already exists.....sometimes) 'MsgBox(sPath & NewPartNum & ".ipt") DeleteFile = DocDoc.FullFileName DocDoc.SaveAs(sPath & NewPartNum & ".ipt", False) 'Delete Old Files (Enable at your own risk!) Try My.Computer.FileSystem.DeleteFile(DeleteFile) Catch MessageBox.Show(DeleteFile & vbLf & " . . . can not delete file, or file not found.", "iLogic") End Try Catch MessageBox.Show(NewPartNum & " Could not be saved. This is detail " & oDetail, "DEBUG CODE: " & oDetailCount & RenameCount & DocDoc.DisplayName) 'Return End Try Next 'Reorder the browser ThisApplication.CommandManager.ControlDefinitions.Item _ ("AssemblyBonusTools_AlphaSortComponentsCmd").Execute 'Set a reference to the top node of the active browser Dim oTopNode As BrowserNode oTopNode = oDoc.BrowserPanes.ActivePane.TopNode Dim oNode As BrowserNode For Each oNode In oTopNode.BrowserNodes ' If the node is visible and expanded, collapse it. If oNode.Visible = True And oNode.Expanded = True Then oNode.Expanded = False End If Next 'Return view to Home view ThisApplication.CommandManager.ControlDefinitions.Item _ ("AppViewCubeHomeCmd").Execute 'zoom all ThisApplication.ActiveView.Fit 'Update InventorVb.DocumentUpdate() End Sub Function RangeBoxFunction(ByVal PartComDef As PartComponentDefinition) As Inventor.Box Dim RangeBox As Inventor.Box = PartComDef.RangeBox Return RangeBox End Function Function GetRangeBoxVolume (ByVal PartRangeBox As Inventor.Box) As Double Dim MinPoint(2) As Double Dim MaxPoint(2) As Double PartRangeBox.GetBoxData(MinPoint, MaxPoint) Dim XSize As Double = MaxPoint(0) - MinPoint(0) Dim YSize As Double = MaxPoint(1) - MinPoint(1) Dim ZSize As Double = MaxPoint(2) - MinPoint(2) Return XSize * YSize * ZSize End Function
Thank you for your mail, I will try the options provided by you.
Thank you for your time.
I had tried the code provided by you, but unfortunately when i run the rule, it showing error message, please find attached snapshot for the same.
In addition, i had copied the entire code into note pad and certain code lines got splitted into two lines and edited to show in a single line, but still i am observing same error message.
Is it possible to upload the code in ".txt" format?
Is there any settings to be done in Inventor I-logic before running this code?
I am not aware of VB, i don't how to arrange/modify the codes.
Please let me know.
I don't know what your error is but the .txt file is attached
I had tried the code which you have sent in note pad, but still its not working.
Again I am getting same error message.
Is there any limitations in using this rule.
I have one assembly with few i-Logic rules and I want to include this rule to rename the components.
Is there any alternate work around to run this rule.
Please let me know
Hi
I discovered that the code gets confused by sub-assemblies. I've modified the code so it doesn't get confused anymore but be aware that I have written this code for my situation so I cannot guarentee that it will do what you want it to do.
IThanks for your reply.
had tried the code.
It's not showing any error message.
I had created sample assembly with 5 part files.
When I run the code, i am not seeing any changes.
Is there anything I want to modify before running this code.
Please let me know.
Like I said I wrote the code for my own situation. The code only renames parts that are contained in the same directory as the parent assembly. The code renames the parts based on a naming scheme that we use in the company I work for which obviously won't be useful for you.
Your code simply renames the nodes in the browser where as my code does a SaveAs on the nodes and deletes the orginal file.
