Remove "Autodesk A360" tab from Inventor 2016 Ribbon
I have unloaded the 360 Add-Ins from Inventor 2016 but the Ribbon still has the Autodesk A360 Tab and I would like to remove it for all of our CAD users.
Does anyone know how to diable the Autodesk A360 Ribbon Tab?
Add-Ins Removed
Autodesk.Configurator360.Inventor.addin
autodesk.InventorConnect.inventor.addin
I Checked them manually and the Addin xml shows them as blocked.
"%appdata%\Autodesk\Inventor 2016\Addins\AddInLoadRules.xml
<Id Policy="Block">{84018CD0-D6DD-4A2F-AD44-1048D919FD9B}<!--Connected Design on A360--></Id>
<Id Policy="Block">{90A53562-92D0-48E1-82C1-48507F10DA73}<!--Autodesk.Configurator360.Inventor--></Id>
Also had a hunt around in these locations for more interface XML files but nothing useful so far:
C:\ProgramData\Autodesk\Inventor Addins
C:\ProgramData\Autodesk\Inventor 2016\Addins
wayne.brill
The “Autodesk 360” is built-in tab, not created by an addin.
The Inventor API does support access to the Inventor Ribbon and you could delete that ribbon tab. Here is a VBA example that shows this.
Sub Test()
    Dim oRibbon As Ribbon
    For Each oRibbon In ThisApplication.UserInterfaceManager.Ribbons
        Dim oTab As RibbonTab
        Debug.Print oRibbon.InternalName
        Set oTab = oRibbon.RibbonTabs("id_OnlineTab")
        oTab.Delete
    Next
End Sub
You could also hide it in OnEnvironmentChange and OnResetRibbonInterface events. Here is a VBA example of the OnEnvironmentChange event:
 Private Sub oUserInterfaceEvents_OnEnvironmentChange(ByVal Environment As Environment, ByVal EnvironmentState As EnvironmentStateEnum, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
    If BeforeOrAfter = kAfter Then
        Set oRibbon = ThisApplication.UserInterfaceManager.ActiveEnvironment.Ribbon
        For Each oTab In oRibbon.RibbonTabs
            If oTab.DisplayName = "Autodesk A360" Then
                oTab.visible = False
                Exit For
        Next
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Hi Wayne,
Deleting the ribbon tab worked very well, thanks for your help..
I found some similar VBA sample code in the API help file in a hunt for the internal name of the ribbon but hand't got it working yet!
Is the internal name simply "id_OnlineTab"?
This is what I had found from code below:
Tab: Autodesk A360, id_OnlineTab, Visible: True
API Sample exerpt "Public Sub PrintRibbon()"
        Print #1, "Ribbon: " & oRibbon.InternalName
        Print #1, "    QAT controls"
        Call PrintControls(oRibbon.QuickAccessControls, "            ", 0)
            Print #1, "    Tab: " & oTab.DisplayName & ", " & oTab.InternalName & ", Visible: " & oTab.Visible
            Dim oPanel As RibbonPanel
            For Each oPanel In oTab.RibbonPanels
                Print #1, "        Panel: " & oPanel.DisplayName & ", " & oPanel.InternalName & ", Visible: " & oPanel.Visible
                Call PrintControls(oPanel.CommandControls, "            ", 0)
                If oPanel.SlideoutControls.Count > 0 Then
                    Print #1, "            --- Slideout Controls ---"
                    Call PrintControls(oPanel.SlideoutControls, "            ", 0)
            Next
HenrikRaboese
the MACRO-solution it's not working perfect. The problem is: the DEFAULT.IVB (user VBA projects) dosn't support events (GUI or User).
A other solution is:
 - export the user-defined-properties for menu and ribbon
 - open the xml file (Location: %APPDATA%\local\autodesk\inventor<VERSION>\preferences\ <YOUR-NAME-HERE>.xml
In this file search for node:
  <Ribbon>
    <InvRibbonUICustomization ....>
      <RibbonStates>
        <Ribbon RibbonID="ZeroDoc">
          <RibbonControl ....>
            <Tabs>
               <!-- !!PASTE THE FOLLOWING NODE TO ADD HERE!! -->
              <Tab Cookie="Tab=id_GetStarted" IsActive="False" IsVisible="True">
and add this on the described node entry:
			  <Tab Cookie="Tab=id_OnlineTab" IsActive="False" IsVisible="False">
				<Panel />
			  </Tab>
Now you can import the xml file for menu and ribbon - and the A360 is not shown.
Have Fun
Henrik
