RegAsm: error RA0000
3 REPLIES 3
w.pepping
2289 Views, 3 Replies
I have an add in and have registered it on a 32-bit machine without any problems. Later I did it on a 64 bit (windows 7)system with the "Register64.bat" and it wordks.
Now I will install the add-in on another 64bit windows 7 system and I get the next error:
RegAsm error RA0000 : unable to locate input assembly 'InventorMatProp.dll' or one of its dependencies
I've made a folder in Program files, copied InventorMatprop.dll and Register64.bat in it and run the bat-file.
I hope someone knows te solution for this problem.
Get control of your sheet metal files.
Download the app from matprop.com
3 REPLIES 3
w.pepping
in reply to: w.pepping
I just tried to install UI_Ribbon_Demo sample from from Brians Mod the Machine and the same error apears. It looks like the problem is not in the dll or .BAT file.
DaveWhiteley
This isn't a Win 7 SP1 problem?? i've seen it as well.
Dave
w.pepping
in reply to: DaveWhiteley
I think you're right. SP1 can be the problem.
Wim
http://www.peppingmd.nl
