Greetings... Happy New Year 2015.
Hi One & All,
I'm facing a problem with iLogic. I have bunch of Parts in which few Parts contains iLogic rules and few does not contain any rules.
I could able to trigger the Rules through VBA, using iLogicAuto.runrule oPrtDoc, RuleName
But, this is failing as some of Parts does not contain any Rules.
All I need to put a condition to check, whether the Part contain iLogicRules > If yes then Run the Rule. For Example...
If iLogicAuto.RuleExists ("RuleName") then 'Only for Example, this is not a code
end if
Regards
NKalyan
