Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Reg : Custom Ribbon tab
6 REPLIES 6
deva_bhansali
991 Views, 6 Replies
Hi everyone,
So far, I worked with macros and did well. I have started with template.
Would like to work on Inventor Add-ins/ Pluggins.
I have gone through the help provided in this and reg. templates. But, it would be helpful if anyone tell me what mistake I'm doing in code.
I need to create a custom ribbon tab. Please find the code.
However this is same code published in _http://adndevblog.typepad.com/manufacturing/2013/07/creating-a-ribbon-item-for-inventor.html
Anyone's help is appreciated in starting-up..
PublicSub Activate( _
      ByVal addInSiteObject As Inventor.ApplicationAddInSite, _
      ByVal firstTime AsBoolean) _
    Implements Inventor.ApplicationAddInServer.Activate
  ' Inventor application
  m_inventorApplication = addInSiteObject.Application
  ' get the command manager control definition
  Dim conDefs As Inventor.ControlDefinitions = _
      m_inventorApplication. _
      CommandManager.ControlDefinitions
  ' our custom command ID
  Dim idCommand1 AsString = "ID_COMAND_1"
  Try
    ' try get the existing command definition
    _defComando1 = conDefs.Item(idCommand1)
  Catch ex AsException
    ' or create it
    _defComando1 = conDefs.AddButtonDefinition( _
        "Command 1", idCommand1, _
        CommandTypesEnum.kEditMaskCmdType, _
        Guid.NewGuid().ToString(), _
        "Command 1 description", _
        "Command 1 Tooltip", _
        GetICOResource("ProjetName.StdIcon.ico"), _
        GetICOResource("ProjetName.Large.ico"))
  EndTry
  If (firstTime) Then
    If (m_inventorApplication.UserInterfaceManager.
        InterfaceStyle =
        InterfaceStyleEnum.kRibbonInterface) Then
      ' 1. access the Zero Doc ribbon
      Dim ribbonPart As Inventor.Ribbon =
          Ribbons.Item("ZeroDoc")
      ' 2. create our custom tab
      Dim tabSampleBlog As Inventor.RibbonTab =
        ribbonPart.RibbonTabs.Add( _
          "Sample Blog", _
          "TAB_SAMPLE_BLOG", _
          Guid.NewGuid().ToString())
      ' 3. criar um painel
      Dim pnlMyCommands As Inventor.RibbonPanel =
        tabSampleBlog. _
        RibbonPanels.Add("My Command", _
                         "PNL_MY_COMMANDS", _
      ' 4. colocar o botão no painel
      pnlMyCommands.CommandControls.AddButton(_defComando1, True)
    EndIf
  EndIf
  ' register the method that will be executed
  AddHandler _defComando1.OnExecute, AddressOf Command1Method
EndSub
' must be declared at the class level
Private _defComando1 As Inventor.ButtonDefinition
PrivateSub Command1Method()
  ' ToDo: do your code here
EndSub
PrivateFunction GetICOResource( _
                  ByVal icoResourceName AsString) AsObject
  Dim assemblyNet As System.Reflection.Assembly = _
    System.Reflection.Assembly.GetExecutingAssembly()
  Dim stream As System.IO.Stream = _
    assemblyNet.GetManifestResourceStream(icoResourceName)
  Dim ico As System.Drawing.Icon = _
    New System.Drawing.Icon(stream)
  ReturnPictureDispConverter.ToIPictureDisp(ico)
EndFunction
The PictureDispConverter converter is based on this AU class by Philippe Leefsma. Below is the piece required here converted to VB.NET
PublicNotInheritableClassPictureDispConverter
  <DllImport("OleAut32.dll",
    EntryPoint:="OleCreatePictureIndirect",
    ExactSpelling:=True, PreserveSig:=False)> _
  PrivateSharedFunction OleCreatePictureIndirect( _
    <MarshalAs(UnmanagedType.AsAny)> picdesc AsObject, _
    ByRef iid AsGuid, _
    <MarshalAs(UnmanagedType.Bool)> fOwn AsBoolean _
    ) AsIPictureDisp
  EndFunction
  Shared iPictureDispGuid AsGuid = GetType( _
    IPictureDisp).GUID
  PrivateNotInheritableClassPICTDESC
    PrivateSubNew()
    EndSub
    'Picture Types
    PublicConst PICTYPE_UNINITIALIZED AsShort = -1
    PublicConst PICTYPE_NONE AsShort = 0
    PublicConst PICTYPE_BITMAP AsShort = 1
    PublicConst PICTYPE_METAFILE AsShort = 2
    PublicConst PICTYPE_ICON AsShort = 3
    PublicConst PICTYPE_ENHMETAFILE AsShort = 4
    <StructLayout(LayoutKind.Sequential)> _
    PublicClassIcon
      Friend cbSizeOfStruct AsInteger = Marshal.SizeOf( _
        GetType(PICTDESC.Icon))
      Friend picType AsInteger = PICTDESC.PICTYPE_ICON
      Friend hicon AsIntPtr = IntPtr.Zero
      Friend unused1 AsInteger
      Friend unused2 AsInteger
      FriendSubNew(icon__1 As System.Drawing.Icon)
        Me.hicon = icon__1.ToBitmap().GetHicon()
      EndSub
    EndClass
    PublicClassBitmap
        GetType(PICTDESC.Bitmap))
      Friend picType AsInteger = PICTDESC.PICTYPE_BITMAP
      Friend hbitmap AsIntPtr = IntPtr.Zero
      Friend hpal AsIntPtr = IntPtr.Zero
      Friend unused AsInteger
      FriendSubNew(bitmap__1 As System.Drawing.Bitmap)
        Me.hbitmap = bitmap__1.GetHbitmap()
      EndSub
    EndClass
  EndClass
  PublicSharedFunction ToIPictureDisp( _
                    icon As System.Drawing.Icon _
                    ) AsIPictureDisp
    Dim pictIcon AsNewPICTDESC.Icon(icon)
    Return OleCreatePictureIndirect(pictIcon, _
                                    iPictureDispGuid, True)
  EndFunction
                    bmp As System.Drawing.Bitmap _
                    ) AsIPictureDisp
    Dim pictBmp AsNewPICTDESC.Bitmap(bmp)
    Return OleCreatePictureIndirect(pictBmp, _
  EndFunction
EndClass
The area highlighted in color is giving errors as there's something is missing
6 REPLIES 6
adam.nagy
in reply to: deva_bhansali
I cannot see what is supposed to be highlighted in the code.
What exact error are you getting and on which exact line?
Cheers,
Adam Nagy
Autodesk Platform Services
deva_bhansali
in reply to: adam.nagy
Hi Adam,
Thanks for the reply. I would like to create a New ribbon menu in Autodesk Inventor Environement.
Presently, I have create a button under  > Tools Ribbon.
It would be helpful if you give me an idea of creation of New Ribbon menu like Model, Inspect, Tools etc.
~Deva
adam.nagy
As I mentioned I could not see anything highlighted in the code you pasted, so I do not know which line is failing for you.
One thing that you may be missing is which Ribbon you are adding the tab to. Augusto's sample added it to the ZeroDoc enviroment, e.g. the one when nothing is opened inside Inventor.
If you want to add a tab to e.g. the Ribbon used inside an assembly then you would get it through
m_inventorApplication.UserInterfaceManager.Ribbons.Item("Assembly")
Adam Nagy
naresh_kalyan
Hi all,
The same way I have started creation of DLL. I'm done with it. But, when I wanted to change the icon instead of standard icon i.e. addin.ico. It is prompting as shown error as attached.
Can anyone let me know, what I need to do to add my own Icon file?
AIP2014, VS2010 (VB.NET)
Regards
NKalyan
Ok, I figured it out and I fixed the issue. But, Another quesiton.....
Another question: can anyone tell me, how to make a Button visible in couple of cases like if Drawing opened & No document opened.
Dim ribbon As Inventor.Ribbon = uiMan.Ribbons("Drawing" and "ZeroDoc"). 'May be an odd syntax, but I put to show the logic
Button1: I want to Press the Button to do update, save & Close on a Drawing document which is active.
Button2: I want to run a "for loop" without opening any document, which opens, Updates & Closes multiple drawing documents on specified location.
These things I'm able to do in VBA enviroment. Now, I'm creating a Add-in. Please, help me...
Regards
NKalyan
