Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Reflection C#
1 REPLY 1
rjay75
309 Views, 1 Reply
Reflection C#
Is reflection of properties supported in the 2013 api. In 2011 I would use refelction to get the value of properties from objects via a generic method. However in 2013 the properties aren't being reflected anymore. For instance the WorkAxis object only has a Visible property refelected.
Has something changed with the members of the types in .NET?
1 REPLY 1
ekinsb
in reply to: rjay75
We generate the interop the same way as we always have.  What has changed is that we're using .Net Framework 4 to generate it.  Is your project using .Net Framework 4?  If it is, then possibly the .Net utility that builds the interop has changed.
Brian Ekins
Mod the Machine blog
