Hey Guys, just wondering if anyone out there knows if it is possible to access a DocumentDescriptor type interface for a PartsListRow. I'm looking for the path to the file in which the row information is based.
I know about the BOMRow functionality and am using this a work around, just my partslists on different pages has some configuration by the user that I would like to use to filter out results.
Any insight would be appreciated.
Solved by adam.nagy. Go to Solution.
Hi Andrew,
The PartsListRow.ReferencedRows gives back DrawingBOMRows which have a BOMRow property.
And that has a ComponentDefinitions set.
Cheers,
Perfect, that's exactly what i need, thanks!
