Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Read / Change Prompted entry through code from titleblock
3 REPLIES 3
GeorgK
779 Views, 3 Replies
Hello together,
how could I read / change prompted entry through code from titleblock (for example DIN) within VB.Net?
Thank you Georg
3 REPLIES 3
GeorgK
in reply to: GeorgK
How could I get the order for the items (for the array)?
tuliobarata
in reply to: GeorgK
I made something like that some days ago, my code is very simple, using parts from the Programming help, but its working :).
I just put it linked to a form and some parameters, So ai can change the text from any Prompted Entry in the title block:
I cleaned the code because it was too long, if you dont understand plz post it, that ill try explain a little better:
Imports  Inventor.UnitsTypeEnum
' Create Custom Paramteres if not done.Dim oPartDoc as DrawingDocument = ThisDoc.Document
Dim userParams As UserParameters = oPartDoc.Parameters.UserParameters
Dim parametro As String
Dim oSheet As Sheet
Dim oTitleBlock as TitleBlock
Dim oTextBox As TextBox
Dim oTextBoxes as TextBoxes
Dim carimbo As String
oSheet = ThisApplication.ActiveDocument.ActiveSheet
    If oSheet.TitleBlock Is Nothing Then Exit Sub
    oTitleBlock = oSheet.TitleBlock
        If oTitleBlock.Definition.Sketch.TextBoxes Is Nothing Then Exit Sub
        oTextBoxes = oTitleBlock.Definition.Sketch.TextBoxes
'---------------------------------------------------------------------------------------------------------------'read the Prompted entryTry
parametro = "PROMPTED ENTRY PARAMETER NAME"
  i = oPartDoc.Parameters(parametro)
  Catch
      For Each oTextBox In oTextBoxes
            If oTextBox.Text = "PROMPTED ENTRY NAME" Then Exit For
            Next
                If oTitleBlock.GetResultText(oTextBox) = "X" Then
                    criacao = True
                Else
                    criacao = False
                End If
      Dim newParam As UserParameter = userParams.AddByValue(parametro,criacao,kBooleanUnits)
  End Try
'write the Prompted entry            For Each oTextBox In oTextBoxes
            Next
                If Parameter("PROMPTED ENTRY PARAMETER NAME") = True Then
                carimbo = "X"
                Else
                carimbo = ""
                End If
                If oTextBox Is Nothing Or oTextBox.Text <> "Botão - P/ Referência" Then Exit Sub
                oTitleBlock.SetPromptResultText( oTextBox, carimbo )
IV 2013
GeorgK,
one more blog may help you:
http://adndevblog.typepad.com/manufacturing/2012/07/getset-the-prompted-text-in-the-border-of-a-shee...
Please mark tuliobarata's message as a solution if you think it helps you.
