Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
"Object variable or With block variable not set" error declaring a worksurface
1 REPLY 1
jpblower
2349 Views, 1 Reply
I get an error
Run-time error '91':
when running this code
Option Explicit
Dim oWorkSurf As WorkSurface
Dim oWorkSurfs As WorkSurfaces
Dim oSurfBody As SurfaceBody
Dim oSurfBodies As SurfaceBodies
Dim oCompDef As ComponentDefinition
Dim oPartCompDef As PartComponentDefinition
Dim oPartDoc As PartDocument
Dim oSplitFeat As SplitFeature
Public Sub SplitAllFaces()
    Set oPartDoc = ThisApplication.ActiveDocument
    Set oPartCompDef = oPartDoc.ComponentDefinition
    Set oSurfBodies = oPartCompDef.SurfaceBodies
    Set oWorkSurfs = oPartCompDef.WorkSurfaces
    oWorkSurf = oWorkSurfs.Item("Srf5")
    For Each oSurfBody In oSurfBodies
        Set oSplitFeat = oPartCompDef.Features.SplitFeatures.SplitBody(oWorkSurf, oSurfBody)
    Next oSurfBody
End Sub
 I'm not sure why.  I've tried Item ("Srf5"), Item(1), and Item("Surface2").  All give the same result.
1 REPLY 1
jpblower
in reply to: jpblower
Found the answer, oWorkSurface=.... needs to be   Set oWorkSurface=.....
