Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
"Gross" weight of an assembly
1 REPLY 1
379 Views, 1 Reply
I work for a company that designs steel structures.  We use standard shape steel for the vast majority of what we make.  Given that, we need to know a fairly accurate weight of the steel to be ordered.  At first I thought the solution was to simply display the iProperties.Mass in a message box using ilogic.  Then I realized that this is the "net" weight of the assembly (minus all features such as extrusion cuts, holes, etc.)
Is it possible, using ilogic, to display the total "gross" weight of an assembly using ilogic?  I've stumbled across some code that will turn off the features in a part and from there I could obtain the correct mass, but I'm needing to do something like this from an assembly.
Any help would be greatly appreciated!
1 REPLY 1
Vladimir.Ananyev
Hope this post is useful in your case
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-Formual/td-p/3432217/highlight/...
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
