Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Question to Represantions in Inventor witk iLogic
5 REPLIES 5
j_weber1
422 Views, 5 Replies
Hallo Everybody,
last time i found an article about sheet in drawings. There is a discproption about filling an multi-value parameter with sheet names of a drawing
If you want to show all the sheet names in the Form, then the easiest might be to use a Multi-Value User Parameter.
1) Create a Multi-Value User Parameter (named e.g. Sheets) in the drawing document through Manage >> Parameters, and turn it into a Multi-Value parameter by right-clicking on it and selecting Make Multi-Value - you don't have to set the values, the below rule will do that
2) Create a rule that will keep the values of that parameter up-to-date: Sheets rule
	Dim MyArrayList As New ArrayList
For Each s In ThisDoc.Document.Sheets
  MyArrayList.Add(s.Name)
Next
	MultiValue.List("Sheets") = MyArrayList
Now i want the same funktion for reprensations in a part or an assembly. So I change sheets with reprensatation, but it is not so easy like i think.
I'm searching the community but i did't found the answer.
Can someone help me to find the right way
thanks a lot
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
5 REPLIES 5
philippe.leefsma
in reply to: j_weber1
You would need to take a look at some examples in order to find out what is the correct syntax.
Here are 2 links I could spot by quickly doing a search on the web...
http://www.mastergraphics.com/wordpress/2013/controlling-positional-representations-with-ilogic/
http://forums.autodesk.com/t5/inventor-customization/ilogic-controling-part-design-view-representati...
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
j_weber1
in reply to: philippe.leefsma
Thanks Philippe for the two links.
I Will look at the links and try to find out what I need.
Have a nice day and a good start in 2015
Jörg
Jörg Weber
j_weber1
Hi Philippe once again,
I look at the links and i must say, that I found the links by my self.
But there is no solution of my idea.
My idea is to create a rep and fill an user parameter with the names of the rep over an ilogic rule.
Like in the exemple that i post first
Jörg Weber
philippe.leefsma
How about that?
Dim compDef As AssemblyComponentDefinition
compDef = ThisDoc.Document.ComponentDefinition
Dim ar As New ArrayList
Dim rep As DesignViewRepresentation
For Each rep In compDef.RepresentationsManager.DesignViewRepresentations
    ar.Add(rep.Name)
Next
MultiValue.List("param1") = ar
Philippe Leefsma
j_weber1
Hi philippe, I'm sorry that i read your message today. I was not in the office the last weeks.
but I will say thanks a lot for your answer and I will test it.
But I think thats the solution for my question.
Thanks a lot for your help. I hope that I can create one day the rules by my self.
Have a nice day
Jörg
Jörg Weber
