Inventor Customization
Active Contributor
liminma8458
Message 1 of 14 (219 Views)
Question on Running commands using API: how to provide 2 inputs through API?
219 Views, 13 Replies
02-06-2013 10:52 AM
Hi
Brian Ekins gave a good information on how to Run Commands Using the API. And he also shows API can provide one sets of input to the command.
In my case, the Inventor command "analyze interference" need two sets of inputs. I tried to feed the commands with two selectset input throght API (see attached code). But the command looks like only take one set of them.So the behavior is not what I want.
So if it is possible,  how to provide 2 set of pre-defined input to inventor commands throught API?
Thank you very much for the help.
Limin
gavin.b
Message 2 of 14 (213 Views)
Re: Question on Running commands using API: how to provide 2 inputs through API?
02-06-2013 12:46 PM in reply to: liminma8458
I believe the problem you are having here is because the dialog box still shows and wants you to select "OK."
As you can't provide the "OK" via the API, you can't complete the command.
In Brian Ekins' blog post he said this:
" Most commands, even if they support pre-selection of entities, will still allow additional selection so they will still require user input.  For example the Fillet command will take any pre-selected edges as input but still displays the dialog to allow the user to select more edges and specify any other options."
I don't think you can finish the analyze interference command through the API call.
gavin.b
Message 3 of 14 (208 Views)
02-06-2013 12:51 PM in reply to: liminma8458
Why not use the method that is already provided in the API rather than running the command using CommandManager?
AssemblyComponentDefinition.AnalyzeInterference( Set1 As ObjectCollection, [Set2] As Variant ) As InterferenceResults
Active Contributor
liminma8458
Message 4 of 14 (207 Views)
02-06-2013 12:52 PM in reply to: gavin.b
The program runs well, but only take the first set to do the analysis. What I want is to analyse the first set against the second set.
Active Contributor
liminma8458
Message 5 of 14 (206 Views)
02-06-2013 12:54 PM in reply to: liminma8458
I want the highlight effect of the interference volumn as in the command. The API does not provide that
gavin.b
Message 6 of 14 (204 Views)
02-06-2013 12:56 PM in reply to: liminma8458
Get the InterferenceResult.InterferenceBody (which is a SurfaceBody) and display it using ClientGraphics?
Active Contributor
liminma8458
Message 7 of 14 (192 Views)
02-06-2013 01:02 PM in reply to: gavin.b
Just wonder how to reach the object of "InterferenceResult.InterferenceBody", the Interferenceresult only shows centroid, occurrenceone,occurrencetwo, type and volume (double type). oResults.InterferenceBody returns error. as attached
How to do that? thanks
gavin.b
Message 8 of 14 (186 Views)
02-06-2013 01:22 PM in reply to: liminma8458
Try this:
Public Sub ShowInterference()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oSelect1 As ComponentOccurrence
    Set oSelect1 = oDoc.SelectSet.Item(1)
    Dim oSelect2 As ComponentOccurrence
    Set oSelect2 = oDoc.SelectSet.Item(2)
    Dim oCheckSet As ObjectCollection
    Set oCheckSet = ThisApplication.TransientObjects.CreateObjectCollection
    Call oCheckSet.Add(oSelect1)
    Call oCheckSet.Add(oSelect2)
    Dim oIntBody As SurfaceBody
    Set oIntBody = oDoc.ComponentDefinition.AnalyzeInterference(oCheckSet).Item(1).InterferenceBody
    ' Create the ClientGraphics object.
    Set oClientGraphics = oCompDef.ClientGraphicsCollection.Add("Sample3DGraphicsID")
        ' Create a new graphics node within the client graphics objects.
        Dim oSurfacesNode As GraphicsNode
        Set oSurfacesNode = oClientGraphics.AddNode(1)
        Dim oBody As SurfaceBody
        Set oBody = oIntBody
        ' Create client graphics based on the transient body
        Dim oSurfaceGraphics As SurfaceGraphics
        Set oSurfaceGraphics = oSurfacesNode.AddSurfaceGraphics(oBody)
        ' Update the view to see the resulting curves.
        ThisApplication.ActiveView.Update
End Sub
Select two components that interfere and then runthe routine. After you have run it, hide the 2 components and you'll see the interference body left over.
Active Contributor
liminma8458
Message 9 of 14 (179 Views)
02-06-2013 02:07 PM in reply to: gavin.b
The above line does NOTwork. InterferenceBody is not recognized.  "oDoc.ComponentDefinition.AnalyzeInterference(oCheckSet).Item(1) " only has centroid, occurrenceone,occurrencetwo, type and volume (double).
More advise?
gavin.b
Message 10 of 14 (176 Views)
02-06-2013 02:14 PM in reply to: liminma8458
I wouldn't post code on here if I hadn't tested it myself.... :smileyhappy:
2. Select them both
3. Run macro, interference is left behind
