Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Question about Microsoft VB 2008 express
4 REPLIES 4
karthur1
314 Views, 4 Replies
Going thru the "My First Inventor Plug-in" tutorial and ran into an issue in Lesson2.  I am trying to add the "Autodesk.Inventor.Interop.dll" as a reference.
When I browse to the correct folder and add this, it shows in the browser as "The system cannot find the reference specified".
Of course, with this being the case, I can't proceed to the next step in the lesson.
Any ideas on how to get VB to find the reference path?
4 REPLIES 4
rjay75
in reply to: karthur1
If it's missing from your references list you need to browse to the Inventor bin and select it. It may be in C:\Program Files\Autodesk\Inventor 20xx\Bin or C:\Program Files\Autodesk\Inventor 20xx\Bin\Public Assemblies depending on your Inventor version.
karthur1
in reply to: rjay75
That is what I did.  I browsed to the C:\Program Files\Autodesk\Inventor 2014\Bin\Public Assemblies folder and selected the "Autodesk.Inventor.Interop.dll" there.
rjay75
If you're looking for the interop then you will be using .NET. You will have to upgrade the version of visual studio you're using. 2014 uses a newer version of .NET then VS 2008 supports.
karthur1
in reply to: rjay75
Ok. thanks,  Will give that a shot.
