Proxy of a workplane inside a pattern inside a part inside an assembly
5 REPLIES 5
oransen
858 Views, 5 Replies
There are many examples of creating rectangular patterns, but not many, if any, of interrogating existing patterns.
I have attached the files and a screenshot of a rectangular part inside an assembly. The part contains a rectangular pattern of holes and workplanes.
My question is how do I get hold of each proxy of the workplane in the pattern?
In other words I don't know what to put in the for loop at the end of this code fragment:
        If _invApp.Documents.Count = 0 Then
            MsgBox("Need to open an the assembly document")
            Return
        End If
        If _invApp.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
            MsgBox("Need to have an Assembly document active")
            Return
        End If
        Dim asmDoc As AssemblyDocument
        asmDoc = _invApp.ActiveDocument
        Dim asmDef As AssemblyComponentDefinition
        asmDef = asmDoc.ComponentDefinition
        Dim occurrences As ComponentOccurrences
        occurrences = asmDef.Occurrences
        Dim partOcc As ComponentOccurrence
        ' partOcc = occurrences.ItemByName("Block-with-hole-pattern")
        partOcc = occurrences.Item(1)
        Dim pippo As PartComponentDefinition
        pippo = partOcc.Definition
        Dim features As PartFeatures
        features = pippo.Features
        Dim RecFeatures As RectangularPatternFeatures
        RecFeatures = features.RectangularPatternFeatures
        Dim RecPattern As RectangularPatternFeature
        RecPattern = RecFeatures.Item(1)
        Dim Xparam As Parameter
        Xparam = RecPattern.XCount
        Debug.Print("This pattern has " & Xparam.Value & " x elements")
        Dim i As Integer, j As Integer
        For i = 1 To Xparam.Value
            Debug.Print(i & "   ")
            ' How to get hold of the proxy for the workplane in the pattern source?
        Next i
The fragment assumes you've opened the assembly attached.
5 REPLIES 5
philippe.leefsma
in reply to: oransen
Hi
it's pretty straightforward to get a better idea about how things are structured under the APi by writting some simple VBA code as follow and analyzing the live objects using the VBA debugger.
Public Sub pattern()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim pattern As RectangularPatternFeature
    Set pattern = doc.ComponentDefinition.Features.RectangularPatternFeatures(1)
End Sub
From the video I recorded below, you can deduce that the patterned workplanes are accessible from "PatternElements.Item(idx).ResultFeatures" collection.
The video is watchable here
NB: The first pattern element is empty because it is the patterned feature itself.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
oransen
My question was about getting the proxies of workplanes in patterns inside parts inside assemblies.
I'll do as you suggest, but some documentation would be helpful.
Vladimir.Ananyev
Inventor API Help contains the overview article on proxies:
In the following vba sample  WorkPlaneProxy objects are created using ComponentOccurrence.CreateGeometryProxy(...)  method.
Sub ExplorePatternInComponent()
  Dim oAsmDoc As AssemblyDocument
  Set oAsmDoc = ThisApplication.ActiveDocument
  Dim oAsmDef As AssemblyComponentDefinition
  Set oAsmDef = oAsmDoc.ComponentDefinition
  Dim oOccs As ComponentOccurrences
  Set oOccs = oAsmDef.Occurrences
  Dim oOcc As ComponentOccurrence
  Set oOcc = oOccs.ItemByName("Block-with-hole-pattern:1")
  Dim oDef As PartComponentDefinition
  Set oDef = oOcc.Definition
  Dim oFeatures As PartFeatures
  Set oFeatures = oDef.features
  Set RecFeatures = oFeatures.RectangularPatternFeatures
  Set RecPattern = RecFeatures.Item(1)
  Dim Nx As Integer, Ny As Integer
  Set Xparam = RecPattern.XCount
  If Not Xparam Is Nothing Then
    Nx = Xparam.value
  Else
    Nx = 1
  End If
  Dim Yparam As Parameter
  Set Yparam = RecPattern.YCount
  If Not Yparam Is Nothing Then
    Ny = Yparam.value
  Else
    Ny = 1
  End If
  Debug.Print ("This pattern has " & Nx & " x " & Ny & " elements")
  Dim oPatternElements As FeaturePatternElements
  Set oPatternElements = RecPattern.PatternElements
  Dim oElt As FeaturePatternElement
  Dim sset As SelectSet
  Set sset = oAsmDoc.SelectSet
  Dim i As Integer
  For i = 2 To Nx
    Set oElt = oPatternElements.Item(i)
'    Debug.Print oElt.ResultFeatures.Item(1).Name
    'get work plane object (assume it is the first object
    'in the collection ResultFeatures)
    Dim oWP As WorkPlane
    Set oWP = oElt.ResultFeatures.Item(1)
    'Debug.Print oWP.Name
    'get proxy object
    Dim oWpProxy As WorkPlaneProxy
    Set oWpProxy = Nothing
    Call oOcc.CreateGeometryProxy(oWP, oWpProxy)
    'now you can do something useful with oWpProxy
    Call sset.Select(oWpProxy)
  Next
  Beep
End Sub
 cheers
Vladimir Ananyev
oransen
in reply to: Vladimir.Ananyev
Magic, thanks! The VB worked, and it took me some time to convert to C++, but I got there in the end.
I'd understood creating proxies, but did not understand ResultFeatures...
Vladimir.Ananyev
ResultFeatures is the collection of entities that were included in the pattern operation.  In your model that could be workplane + workaxis in every pattern element.
Vladimir Ananyev
