Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Programmatically making all inputs non-consumed
2 REPLIES 2
353 Views, 2 Replies
I need to be able to programmatically set all inputs to be non-consumed for a C# Inventor 2013 add-in I'm writing. I'm doing this:
InventorPart = (Inventor.PartDocument)Program.InventorApp.ActiveDocument;
foreach(Inventor.PartFeature ipf in InventorPart.ComponentDefinition.Features) { ipf.ConsumeInputs = false; }
Seems straightforward. But when I run it, I get "COMException was unhandled - Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))". Researching this, it looks like it's just a generic COM error.
Any ideas?
2 REPLIES 2
adam.nagy
As far as I know only Stitch and Sculpt features support that, but there might be others.
If you right-click a feature in the user interface and the context menu shows "Consume Inputs" then it is supported for that specific feature type otherwise not. If you get an exception when trying to set it through the API, then it's not supported.
Cheers,
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Ok, I was trying to do the similar thing for sketches (sharing sketches) and thought it was the same, but turns out it has its own option. Thanks!
