Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Profiles
1 REPLY 1
148 Views, 1 Reply
Profiles
I've just created a pipe programmatically, extruded it to a non adaptive
workplane.
What's scary is the fact that Inventor has selected the right region. I'm
also a little concerned by this, how do I specify the correct region? In
the
pipe profile I obviously have 2 circles, one for the Outside diameter and
one for the inside diameter. How did the region between the two circles get
picked and not the region that is the the inside of the inside diameter
circle?
Scott
1 REPLY 1
I assume you have created the outer circle first, than the inner circle?
What if you switch those two? Is the region still correct?
You should be able to define which region you want for you profile...
"Scott Stubbington" wrote in message
news:B4907FD5F36F4F3E3376DEE54D649D94@in.WebX.maYIadrTaRb...
> Hello,
> workplane.
> the
get
> circle?
> Thanks
> Scott
