Procuring points of closest distance [GetMinimumDistance]
10 REPLIES 10
Message 1 of 11
agr.saurav1
1195 Views, 10 Replies
I intend to procure the minimum distance between two cylinders as parts. I also want the closest points. Have created a form in Visual Basic. Howerver, I am receiving the error
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred in mscorlib.dll
Additional information: Operation unavailable (Exception from HRESULT: 0x800401E3 (MK_E_UNAVAILABLE))
 The error occurs for the line
            distance = _invApp.MeasureTools.GetMinimumDistance(comp_occ1, comp_occ2, InferredTypeEnum.kNoInference, InferredTypeEnum.kNoInference, cont)
 Interestingly, the code does not result in an errror when I give just 2 parameters.
Autodesk Inventor 2014
Visual Studio Express 2013
Please help.
Complete code:
 Private Sub ProxSelect2_Click(sender As Object, e As EventArgs) Handles ProxSelect2.Click
        Dim check_doc As Boolean = True
        CheckDocument(check_doc)
        Debug.Print(check_doc)
        If (Not check_doc) Then
            Return
        End If
        Dim asmDoc As AssemblyDocument
        asmDoc = _invApp.ActiveDocument
        If asmDoc.SelectSet.Count <> 2 Then
            MsgBox("Need to select two parts")
            Return
        End If
        Dim SelSet As SelectSet
        SelSet = asmDoc.SelectSet
        Dim comp_occ1 As ComponentOccurrence
        Dim comp_occ2 As ComponentOccurrence
        comp_occ1 = SelSet.Item(1)
        comp_occ2 = SelSet.Item(2)
        'Dim vContext As Object = Nothing
        Dim cont As NameValueMap = Nothing
        Dim distance As Double
            MsgBox("Distance=" & distance * 10)
            If Not cont.Item("IntersectionFound") Then
                Debug.Print(cont.Item("ClosestPointOne").X)
                Debug.Print(cont.Item("ClosestPointOne").Y)
                Debug.Print(cont.Item("ClosestPointOne").Z)
                Debug.Print(cont.Item("ClosestPointTwo").X)
                Debug.Print(cont.Item("ClosestPointTwo").Y)
                Debug.Print(cont.Item("ClosestPointTwo").Z)
            End If
            Return
        Try
        Catch ex As Exception
            MsgBox(ex.ToString())
            MsgBox("SomeError")
            Return
        End Try
    End Sub
10 REPLIES 10
Message 2 of 11
You should create NameValueMap object prior to use it as an argument:
Dim cont As NameValueMap = invApp.TransientObjects.CreateNameValueMap
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
Dear Sir,
Thank you for your reply.
I corrected the code as suggested. However, I am still getting the same error.
The entire code is below for your reference. Please help me out. I have been stuck with this problem for long.
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
        Try
            _invApp = Marshal.GetActiveObject("Inventor.Application")
            Try
                Dim invAppType As Type = GetTypeFromProgID("Inventor.Application")
                _invApp = CreateInstance(invAppType)
                _invApp.Visible = True
                _started = True
            Catch ex2 As Exception
                MsgBox(ex2.ToString())
                MsgBox("Unable to get or start Inventor")
            End Try
        End Try
    End Sub
    Private Sub Form1_FormClosed(ByVal sender As Object, ByVal e As FormClosedEventArgs)
        If _started Then
            _invApp.Quit()
        End If
        _invApp = Nothing
    End Sub
    Public Sub CheckDocument(Optional ByRef check_doc As Boolean = True)
        Debug.Print("No of Documents" & _invApp.Documents.Count)
        If _invApp.Documents.Count = 0 Then
            MsgBox("Need to open an Assembly Document")
            check_doc = False
            Return
        End If
        If _invApp.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
            MsgBox("Need to have an Assembly document active")
            check_doc = False
            Return
        End If
        check_doc = True
    End Sub
    Private Sub VerifySystem_Click(ByVal sender As Object, ByVal e As EventArgs) Handles VerifySystem.Click
        If (check_doc) Then
            MsgBox("System Stable. Proceed")
            Return
        End If
    End Sub
    Private Sub ProxSelect2_Click(ByVal sender As Object, ByVal e As EventArgs) Handles ProxSelect2.Click
            Return
        End If
            Return
        End If
        'Dim cont As NameValueMap = Nothing
        Dim cont As NameValueMap = _invApp.TransientObjects.CreateNameValueMap
        'distance = _invApp.MeasureTools.GetMinimumDistance(comp_occ1, comp_occ2, InferredTypeEnum.kNoInference, InferredTypeEnum.kNoInference, cont)
        distance = _invApp.MeasureTools.GetMinimumDistance(comp_occ1, comp_occ2)
        End If
        Return
        Try
            MsgBox("SomeError")
            Return
        End Try
    End Sub
End Class
Message 4 of 11
You should calculate distance using
distance = _invApp.MeasureTools.GetMinimumDistance( _
    comp_occ1, comp_occ2, _
    InferredTypeEnum.kNoInference, _
    cont)
 then cont object will be filled with values.
Here is quick VBA test that works for me.
Private Sub GetClosestPoints()
    Set asmDoc = ThisApplication.ActiveDocument
    Dim oOccs As ComponentOccurrences
    Set oOccs = asmDoc.ComponentDefinition.Occurrences
    Set comp_occ1 = oOccs.Item(1)
    Set comp_occ2 = oOccs.Item(2)
    Set cont = ThisApplication.TransientObjects.CreateNameValueMap
    distance = ThisApplication.MeasureTools.GetMinimumDistance( _
      cont)
    MsgBox ("Distance=" & distance * 10)
        Debug.Print ("Point 1")
        With cont.Item("ClosestPointOne")
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
        Debug.Print ("Point 2")
        With cont.Item("ClosestPointTwo")
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
    End If
  Dim Intersection As Boolean
  Intersection = cont.Item("IntersectionFound")
  Dim P1 As Point
  Set P1 = cont.Item("ClosestPointOne")
  Dim P2 As Point
  Set P2 = cont.Item("ClosestPointTwo")
  'proxy objects - FaceProxy, EdgeProxy, VertexProxy
  Dim oProxy1 As Object
  Set oProxy1 = cont.Item("ClosestEntityOne")
  Dim oProxy2 As Object
  Set oProxy2 = cont.Item("ClosestEntityTwo")
End Sub
cheers,
Vladimir Ananyev
Message 5 of 11
Sir,
Thankyou for the code. The code works fine. However, after few days of trial, it seems that the error is in the Assembly and not in the code. For certain positions of the parts, the code gives an error. Doesn't make sense, though. I am attaching a sample Assembly, please have a look. If we do not change the position of the parts, the codes (both the add-in I created and the Macro you posted) give the same error. However, it doesn't once the parts are moved! Could this be a bug? Is there some restriction on the parts?
The VBA test code used is the same posted in the above reply.
      cont)
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
    End If
  Dim P1 As Point
  Dim P2 As Point
End Sub
Please advise.
Also, I shifted my codes to form an add-in using the standard add-in template.
Saurav Agarwal
Message 6 of 11
Hi Saurav Agarwal
Can you reproduce this effect in another assembly file or this is accidental case?
I played a bit with your assembly and saw the described error. But I failed to reproduce it in new assemblies that contain both your parts – in new assemblies VBA code works fine for any components configurations.
Cheers,
Vladimir Ananyev
Message 7 of 11
I am attaching a fragment of my original project. Please have a look. The said error occurs for all pairs of cylinders when the "default" positional refresentaition is activated. If we move the parts in the master position, few pairs give the error, while others dont. Is there something wrong with the way the parts are being assembled? Please advise.
Inventor version: 2014 Student Edition
Saurav Agarwal
Message 8 of 11
If case when GetMinimumDistance(comp1,comp2, , ,context) method fails you may apply the alternative approach.  GetMinimumDistance method works fine with two FaceProxy objects that represent component’s faces in the assembly context.  You may Iterate faces collections in both components and find closest faces (and closest points as well).  You may filter faces by their geometry, e.g. taking into account cylinder faces only.
The sample below calculates this distance and finds closest points for the side cylinder faces in components 2 and 5 in the BotAssembly.iam in the situation when the simple method fails.
Sub GetClosestPoints_4()
  Dim oAssyDoc As AssemblyDocument
  Set oAssyDoc = ThisApplication.ActiveDocument
  Dim oOcc1 As ComponentOccurrence
  Set oOcc1 = oAssyDoc.ComponentDefinition.Occurrences.Item(2)
  Dim oOcc2 As ComponentOccurrence
  Set oOcc2 = oAssyDoc.ComponentDefinition.Occurrences.Item(5)
  'face proxy object from the first component
  Dim oPartDef1 As PartComponentDefinition
  Set oPartDef1 = oOcc1.Definition
  Dim oFace1 As Face
'  Set oFace1 = oPartDef1.SurfaceBodies.Item(1).Faces.Item(1)
  Set oFace1 = oPartDef1.features.ExtrudeFeatures.Item(1).SideFaces(1)
  Dim oFaceProxy1 As FaceProxy
  Set oFaceProxy1 = Nothing
  Call oOcc1.CreateGeometryProxy(oFace1, oFaceProxy1)
  'face proxy object from another component
  Dim oPartDef2 As PartComponentDefinition
  Set oPartDef2 = oOcc2.Definition
  Dim oFace2 As Face
'  Set oFace2 = oPartDef2.SurfaceBodies.Item(1).Faces.Item(1)
  Set oFace2 = oPartDef2.features.ExtrudeFeatures.Item(1).SideFaces(1)
  Dim oFaceProxy2 As FaceProxy
  Set oFaceProxy2 = Nothing
  Call oOcc2.CreateGeometryProxy(oFace2, oFaceProxy2)
  Dim context As NameValueMap
  Set context = ThisApplication.TransientObjects.CreateNameValueMap
      oFaceProxy1, oFaceProxy2, _
      context)
  Intersection = context.Item("IntersectionFound")
  If Not Intersection Then
    Dim P1 As Point
    Set P1 = context.Item("ClosestPointOne")
    Dim P2 As Point
    Set P2 = context.Item("ClosestPointTwo")
    'temporary debug print
        With P1
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
        With P2
          Debug.Print (.x)
          Debug.Print (.y)
          Debug.Print (.Z)
        End With
  End If
End Sub
Hope this workaround could help you.
Cheers,
Vladimir Ananyev
Message 9 of 11
What I understand from the above code is that you are creating a proxy face and using it to find distance. but what about the remaining faces? Is there a way to check all the faces? checking all the faces against all the faces of the other part seems to be a heavy computational task. Thanks a lot!
Message 10 of 11
You may access all faces via PartComponentDefinition.SurfaceBodies.Item(1).Faces collection.  Also you may get references to faces from features as it was shown in my previous post.   Filtering faces by geometry and/or area could enhance performance.  SurfaceType property of the Face object returns SurfaceTypeEnum constant that allows filter all cylindrical faces:
Sub AllCylinderFaces()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  Dim oBody As SurfaceBody
  Dim oFace As Face
  For Each oBody In oDef.SurfaceBodies
    For Each oFace In oBody.Faces
      If oFace.SurfaceType = kCylinderSurface Then
        'Do something useful here
        Debug.Print "Area = " & oFace.Evaluator.Area   '   cm^2
      End If
    Next
  Next
End Sub
I’ve logged this case in our database.
Thank you for the sample assemblies!
Vladimir Ananyev
Message 11 of 11
agr.saurav1
in reply to: agr.saurav1
Please let me know if you find a solution or a patch to the initial code, at a later date. The code was easier to implement and faster as well. Thank You!
