Inventor Customization
Active Member
bijibijmak
Message 1 of 3 (233 Views)
Problem with Project Falcon ad-in in Inventor 2013
233 Views, 2 Replies
12-12-2012 09:11 PM
Just downloaded and Installed Project Falcon on my Inventor 2013 (64 bit) educational. Although I enable the ad-in in Inventor and using ad in manager from start menu, I am unable to use it to run simulations.
What can I do?
Valued Contributor
MattH_Work
Message 2 of 3 (227 Views)
Re: Problem with Project Falcon ad-in in Inventor 2013
12-13-2012 03:41 AM in reply to: bijibijmak
I get a similar thing, if I have no geomtery in my model I can enter the Falcon environment, however, if any geometry exists Falcon will crash inventor.
Curtis_Waguespack
Message 3 of 3 (215 Views)
12-13-2012 07:59 AM in reply to: MattH_Work
Hi bijibijmak,
You might get a better response here:
Autodesk Discussion Groups > Autodesk Labs  > Project Falcon
http://forums.autodesk.com/t5/Project-Falcon/bd-p/Falcon
Maybe the moderators can move this topic to that forum to help others in the future.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
