Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Problem with ilogic and paramters
4 REPLIES 4
287 Views, 4 Replies
So I have made an enclosure and used ilogic to change the size, pretty basic. But everytime I unsupress the rule it changes the parameters length,width and height to 0 and wont let me change them. The code is here:
Length = ilength
Width = iwidth
Height = iheight
'Bottom
Parameter("Bottom:1", "Length")=ilength
Parameter("Bottom:1", "Width")=iwidth
'Back wall
Parameter("Back Wall:1", "Height")=iheight
Parameter("Back Wall:1", "Width")=iwidth
'Top
Parameter("Top:1", "Length")=ilength
Parameter("Top:1", "Width")=iwidth
'Side Panels
Parameter("Side Panel:1", "Height")=iheight
Parameter("Side Panel:1", "Length")=ilength
'Middle Wall
Parameter("Middle Wall:1", "Height")=iheight
Parameter("Middle Wall:1", "Width")=iwidth
 Any help would be greatly appreciated
4 REPLIES 4
rjay75
Length = ilength
Width = iwidth
Height = iheight
What is ilength, iwidth, iheight? Are they parameters or just variables? If they are just variables they're default value when the rule runs is 0. Where are the values set at?
in reply to: rjay75
They are just variables, Length, Width, and Height are the user parameters which can be set in either a from or in the parameters menu
rjay75
Then at the very beginning you are setting your parameters to 0 when the rule starts. The variables have a default value of 0 and you're not setting a value to them.
It should look like this at the beginning
ilength = Length
iwidth = Width
iheight = Height
Then you're setting the variables to the values of the parameters at the start.
in reply to: rjay75
Thank you that worked, something so simple.......
