Hi
I find that the method, AddCustomiPartMember , works fine if i pass the "Row" parameter as a number but i can't get it to work when i pass it as a string . This is what the help file states:
Parameters | Description |
Row | Optional input Variant that specifies the row for the member within the factory. The row index is specified either by a Long (row index), a String (part identifier, i.e. ''[Height=1.000 in][Length=2.000 in][Radius=0.250 in]''), or an iPartTableRow object. |
Here's the code that doesn't work :
Sub test3()
Dim myAssembly As AssemblyDocument, my_part As ComponentOccurrence, my_pos As Matrix
Dim ifactory_path As String, ipart_path As String, iselect As String
Set myAssembly = ThisApplication.ActiveDocument
Set my_pos = ThisApplication.TransientGeometry.CreateMatrix
Dim custom_vars(1 To 2) As String
iselect = "[my_var=18mm]"
custom_vars(1) = "13mm"
custom_vars(2) = "25mm"
ifactory_path = "D:\my_ifactory.ipt"
ipart_path ="D:\selected_ipart.ipt"
Set my_part = myAssembly.ComponentDefinition.Occurrences.AddCustomiPartMember(ifactory_path, my_pos, ipart_path, iselect, custom_vars)
End Sub
but if i swap out iselect for a number such as "2" etc then it works fine !!
Can anyone help me out??
Many thanks in advance.
Dan
Solved by xiaodong_liang. Go to Solution.
It is a known issue AddCustomiPartMember does not work with TableRow. Here is some snippet with which we logged this issue.
Dim oTblRowCust As iPartTableRow
Set oTblRowCust = oPartDef.iPartFactory.TableRows.Item(2)
' by number, can work
Call oMatrix.SetTranslation(oTG.CreateVector(300, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear1.ipt", 1)
' 1st Row
'By iPart Table Row, cannot work!
Call oMatrix.SetTranslation(oTG.CreateVector(400, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear2.ipt", oTblRowCust) ' 2nd Row
' By string identifier, cannot work
Call oMatrix.SetTranslation(oTG.CreateVector(500, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear3.ipt", "CustomFactory [d0=2.3][d1=6.937][d2=2.552]")
So, you may have to modify the factory iPart beforehand. Then Insert the ipart by using AddCustomiPartMember method.Sorry for the problem.
Hello.
I'm trying to insert custom iPart using AddCustomiPartMember in Inventor 2019. I want to define row by specifying a string (e.g. "CustomFactory [d0=2.3][d1=6.937][d2=2.552]") and it does not work.
Example I'm trying is from DevBlog. I get the error (Unspecified error) in every line where row is defined by string. Inserting by providing row index works fine.
Should this work in 2019?
Sašo
