problem using AddCustomi​PartMember
3 REPLIES 3
mitcham_boy
603 Views, 3 Replies
Hi
I find that the method, AddCustomiPartMember , works fine if i pass the "Row" parameter as a number but i can't get it to work when i pass it as a string .  This is what the help file states:
Sub AddCustomiPartMember(FactoryFileName As String, Position As Matrix, FullFileName As String, ByRef Row As [optional] VARIANT, ByRef CustomInput As [optional] VARIANT, Result As [out, retval] ComponentOccurrence*)
Parameters
Description
Row
Optional input Variant that specifies the row for the member within the factory. The row index is specified either by a Long (row index), a String (part identifier, i.e. ''[Height=1.000 in][Length=2.000 in][Radius=0.250 in]''), or an iPartTableRow object.
Here's the code that doesn't work :
Sub test3()
    Dim myAssembly As AssemblyDocument, my_part As ComponentOccurrence, my_pos As Matrix
    Dim ifactory_path As String, ipart_path As String, iselect As String
    Set myAssembly = ThisApplication.ActiveDocument
    Set my_pos = ThisApplication.TransientGeometry.CreateMatrix
    Dim custom_vars(1 To 2) As String
    iselect = "[my_var=18mm]"
    custom_vars(1) = "13mm"
    custom_vars(2) = "25mm"
    ifactory_path = "D:\my_ifactory.ipt"
    ipart_path ="D:\selected_ipart.ipt"
    Set my_part = myAssembly.ComponentDefinition.Occurrences.AddCustomiPartMember(ifactory_path, my_pos, ipart_path, iselect, custom_vars)
End Sub
but if i swap out iselect for a number such as "2" etc then it works fine !!
Can anyone help me out??
Many thanks in advance.
Dan
3 REPLIES 3
It is a known issue  AddCustomiPartMember does not work with TableRow. Here is some snippet with which we logged this issue.
Dim oTblRowCust As iPartTableRow
Set oTblRowCust = oPartDef.iPartFactory.TableRows.Item(2)
' by number, can work
Call oMatrix.SetTranslation(oTG.CreateVector(300, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear1.ipt", 1)
' 1st Row
'By iPart Table Row, cannot work!
Call oMatrix.SetTranslation(oTG.CreateVector(400, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear2.ipt", oTblRowCust) ' 2nd Row
' By string identifier, cannot work
Call oMatrix.SetTranslation(oTG.CreateVector(500, 0, 0))
Set oOcc = oAsmCompDef.Occurrences.AddCustomiPartMember(customiPartFile, oMatrix, "C:\temp\gear3.ipt", "CustomFactory [d0=2.3][d1=6.937][d2=2.552]")
So, you may have to modify the factory iPart beforehand. Then Insert the ipart by using AddCustomiPartMember method.Sorry for the problem.
in reply to: xiaodong_liang
Is this still the case with Inventor 2014?
Hello.
I'm trying to insert custom iPart using AddCustomiPartMember in Inventor 2019. I want to define row by specifying a string (e.g. "CustomFactory [d0=2.3][d1=6.937][d2=2.552]") and it does not work.
Example I'm trying is from DevBlog. I get the error (Unspecified error) in every line where row is defined by string. Inserting by providing row index works fine.
Should this work in 2019?
Sašo
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
