Hi
I have an external iLogic rule that is triggered by a VBA. The problem i am havin is that when i edit a sub-part or sub-assembly within an assembly the iLogic rule is run on the overhead assembly.
My iLogic rule is for showing the the weight of the current part/assembly, but when i edit a sub-part or -assembly it shows the weight of the overhead assembly as stated above.
I suspect the problem is within the VBA as i'm not having this problem running the iLogic rule manually
Se VBA code below
Public Sub Weight() RuniLogic "Weight" End Sub Public Sub RuniLogic(ByVal RuleName As String) Dim iLogicAuto As Object Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc Is Nothing Then MsgBox "Missing Inventor Document" Exit Sub End If Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunExternalRule oDoc, RuleName End Sub Function GetiLogicAddin(oApplication As Inventor.Application) As Object Set addIns = oApplication.ApplicationAddIns 'Find the add-in you are looking for Dim addIn As ApplicationAddIn On Error GoTo NotFound Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") If (addIn Is Nothing) Then Exit Function addIn.Activate Set GetiLogicAddin = addIn.Automation Exit Function NotFound: End Function
iLogic Rule used:
MessageBox.Show (Round(iProperties.Mass) & " Kg", "Weight")
Example pictures showing the problem.
