Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Print idw to pdf of automated assembly components
1 REPLY 1
jplujan
470 Views, 1 Reply
With the help of the page http://inventortrenches.blogspot.com.es/, I have the following code that prints pdf a rule, the problem I have is that some of the computers where the rule throws the whole process runs but the end product has not pdf.
Imports System.IO
Sub Main ()
 	Dim jpg_filename As String
 	Dim html_filename As String
 	Dim i As Integer
	Dim oAsmDoc As AssemblyDocument
	Dim ofolder As String
	Dim oDrawDoc As DrawingDocument
	Dim CadenaLibreria As String
	Dim oPath As String
	Dim RUser As String
	Dim oRefDocs As DocumentsEnumerator
	Dim oRefDoc As Document
	html_filename = ThisDoc.PathAndFileName(False) & ".html"
	'Define el documento actual como ensamblaje
	oAsmDoc = ThisApplication.ActiveDocument
	oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
	'Chequea si el documento activo es un ensamblaje
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
	'Entrada de usuario para proceder
	RUser = MessageBox.Show ( _
	"Se van a crear ficheros PDF de todos los ensamblajes." _
	& vbLf & " " _
	& vbLf & "Este proceso llevara algun tiempo.", "Salida Pdf",MessageBoxButtons.YesNo)
	If RUser = vbNo Then
		Return
	Else
 	'Funciones de prerparación de informe
 	VisibilidadPlanos
 	VistaModeloFront
 	CreaFicheroInforme(html_filename)
 	CabeceraInforme(html_filename)
 	CuerpoInforme(html_filename,"kit con incidencias:")
	'Start PDF setup
	oPath = ThisDoc.Path
	PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Vector_Resolution") = 400
		oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'get PDF target folder path
	oFolder = oPath & "\" &  "PDF Kits"
	'Chequea la carpeta Pdf y si no existe la crea
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	'Start Component Drawings
	'look at the files referenced by the assembly
	oRefDocs = oAsmDoc.AllReferencedDocuments
	'work the the drawing files for the referenced models
	'this expects that the model has a drawing of the same path and name
	For Each oRefDoc In oRefDocs
		LongitudRefDoc = Len (Left(orefDoc.FullDocumentName, Len (orefDoc.FullDocumentName)-3) )
		ExtenRefDoc = Right(orefDoc.FullDocumentName, Len (orefDoc.FullDocumentName)-LongitudRefDoc)
		If ExtenRefDoc = "iam" Then
			idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
			iamPathname = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "iam"
			'check to see that the model has a drawing of the same path and name
			If(System.IO.File.Exists(idwPathName)) Then
				oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
				'oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
				oFileName = Left(oDrawDoc.DisplayName, Len(oDrawDoc.DisplayName) -3)
				'MessageBox.Show(odrawdoc.displayname, "Title")
				On Error Resume Next ' if PDF exists and is open or read only, resume next
				'Set the PDF target file name
				oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
				'Write out the PDF
				Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
				'close the file
				oDrawDoc.Close
			Else
					Cadenalibreria = "C.\LIBRERIA"
					Dim eval as Boolean =  Not idwPathname.toUpper.contains("\AIP\")
					If Not idwPathname.toUpper.contains (Cadenalibreria.toUpper) And eval Then
						jpg_filename = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "jpg"
						oIamDoc = 	ThisApplication.Documents.Open(iamPathName, True)
						VisibilidadPlanos()
						VistaModeloIso
						SalvarBitmap(jpg_filename, 1680, 1650)
						oIamDoc.Close
						idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "iam"
						Dim Linea As String = idwPathName
						DatosInforme(html_filename, jpg_filename, Linea)
		Else
	Next
	FinalInforme(html_filename)
	MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
	'open the folder where the new ffiles are saved
	'Shell("explorer.exe " & oFolder,vbNormalFocus)
	VisualizarInforme(html_filename)
End Sub
1 REPLY 1
xiaodong_liang
in reply to: jplujan
It looks the iLogic code missed some other functions. Could you make sure to provide a runable code?
In addition, it will very hard for Autodesk employees or outside peers to jump into such case if it is involved within a complex code logic. It is more helpful to isolate and post a simple code demo. e.g. in this case, are the missing functions related with this problem? Have you tried to commentined out them?
iLogic editor is not able to debug, so in general, a developer would use VB.NET to produce some codes, where the debugging is available. After it works, copy the code from VB.NET to iLogic and make a little modification. This is the most efficient way to write a complex code.
