Possibility to hide iLogic code from end users?
I recently created some iLogic based components. I wonder how difficult it is to protect the iLogic code, similar as VBA code which can be password protected.
The reason being:
1. Of course, to hide & protect the creator's modeling logic;
2. To avoid the relation between parameters being messed up by the end user unintensionally.
I did have the opportunity to raise the question during the Portathon event and the answer was that the protection not directly available, though the workaround could be mixing with some Inventor API coding in .NET.
However, this might defeat one of the benefits of iLogic, simple and ease to use, gentlr learning curve, especially for users with VBA experience. .NET might not be so easy for a lot of engineers from mechanical or other disciplines.
Below are some of my ideas for discussion:
1 Disable the "Edit" button for iLogic components, including rules, forms, etc.;
2. Put all code that are to be protected in an external file, and then make that file unreadable (password protected, or other protection) to un-intended user, however, readable to those who have proper access privelege.
It seems to me that it might be easier to implement by Autodesk Inventor team.
