Hi there,
Subject: Inventor placing Iparts in Assembly (Autodesk Inventor 2010)
Problem:
When placing an Ipart into a project Assembly it will make a copy of that variant and place it in the same map as the Ipart.
So when variant B of Ipart A is selected it will make a copy of variant B in the same folder where Ipart A is located.
Question:
Is it possible to make a “save as” option or another similar manner to save those copies of variant B in a project map of a project assembly?
Instead of saving all the Ipart variants to a single folder. So each time a new project is started they have all the parts in the same folder.
Reason:
I am making a local library for parts that are used for repairs. These parts have many variants and some times need to be customized for a repair.
The current system keeps polluting itself causing the users to loose their parts and accidentally delete the original parts etc.
I contacted Autodesk support and theyrecommended to post this question on this forum. They did mentioned that vba programming could achieve this. I have no knowledge of this type of programming.
Thanks for any input,
Piet Klaas
Hi Piet,
So following code illustrates how to generate an iPart member and move it to a different directory. You cannot choose where the member is going to be saved on the disk first, but the sample illustrates how to retrieve it:
Private Sub CreateAndMoveiPartMember() Dim factoryDoc As PartDocument Set factoryDoc = ThisApplication.Documents.Open("C:\Temp\Factory.ipt") Dim factory As iPartFactory Set factory = factoryDoc.ComponentDefinition.iPartFactory Dim member As iPartMember Set member = factory.CreateMember(1) Dim srcFilename As String srcFilename = factory.MemberCacheDir + "\" + member.name Dim destFilename As String destFilename = "C:\Temp\MembersDir\" + "NewMember1.ipt" Call ThisApplication.FileManager.CopyFile(srcFilename, destFilename) 'Delete the original file, if you'd like to Call ThisApplication.FileManager.DeleteFile(srcFilename) End Sub
In your case, what you will need to do is to insert the iPart in the assembly, retrieve the generated member, do a copy of the physical file to the location of your choice, then use "ComponentOccurrence.Replace" on the relevant occurrence to swap the original iPart member with the new copy.
I hope it helps.
Philippe.
