We are developing a macro for steel structures and we will be very pleased to know about the program to insert or place a content center component in assembly through VBA programming. If there are provisions for changing the object type and changing length in that importing process it will be very helpful.
Hi
Please take a look first at what's doable in the API Help Files samples, see
Place Content Center Parts API Sample
Replace content center part API Sample
I hope it helps,
Philippe.
Yes it's been added few releases ago. There was no API access to CC before, sorry for the bad news.
Please take a look at the 2013 API Help Files, you can find it on the Inventor Developer Center. The version in which the feature was introduced is indicated at the bottom of each property/method. Some of the CC API was introduced in 2010, there has been incremental additions since then.
According to Help Files, looks like 2011 can do it...
Hi
Would you please share your solution?
I want to be able to insert a component from content center as custom and promt the user for a "Length" input.
Best regards/
Jozsef
