place iLogic Component
1 REPLY 1
j.vanderheijden
476 Views, 1 Reply
Is it possible to skip the small preview window and the parameters display when i place an iLogic component white the command Place iLogic Component.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
1 REPLY 1
adam.nagy
in reply to: j.vanderheijden
Happy New Year!
If you don't want the preview window to appear, you don't want the parameters dialog to appear, then the only functionality left is the copying of the file that you want to place.
You could do that using Windows API or e.g. the ThisApplication.FileManager object
Then you could just start the component placement command ("Place") of Inventor with the copied part/assembly like shown in this devblog post: http://adndevblog.typepad.com/manufacturing/2013/01/provide-command-parameters-using-postprivateeven...
In iLogic it would look like this:
Dim cm As CommandManager
cm = ThisApplication.CommandManager
cm.PostPrivateEvent(
	PrivateEventTypeEnum.kFileNameEvent,
	"C:\Users\Administrator\Documents\Inventor\TempProject\part - copy.ipt")
Dim cd As ControlDefinition
cd = cm.ControlDefinitions("AssemblyPlaceComponentCmd")
cd.Execute
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
