Hi Guys,
There is an option called "Visibility" available when you right click on the part name on the browser pane. See the attachced image for the clear task.
I want to Check & UnCheck that programatically using VB.Net.
Is there any way to do it...??
Solved by YuhanZhang. Go to Solution.
The ComponentOccurrence.Visible is used for this purpose.
