I am still new at VBA/API programing so please bare with me. I programmed a Macro to create a coil. To get out of the sketch mode I used the "Finish2dSketchCmd" command after using the "CoilFeature". Now that the coil is made I want to get back into the sketch mode to continue modifying my coil. What command should I use to get back into the sketch mode? I found these two commands "PartNewSketchCmd" and "AppSketch2DWrapperCmd". Which one should I use?
Thank you for your time
WailGM
