I found the following code on Curtis Waguespack site.
http://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
'start of iLogic code---------------------------------------------------------------------------------- 'sort parts list on error resume next Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oPartsList1 As PartsList oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1) 'If oPartsList1 Is Nothing Then Resume Next oPartsList1.Sort("PART NUMBER") oPartsList1.Renumber oPartsList1.SaveItemOverridesToBOM
Is there a way to have the Collum Width bypass the predefined setting from the Styles, to have them auto adjust?
Maybe I'm missing something but I did not find in the user interface where to set a column to auto-adjust. :-s
But it sounds as if you've found such a setting, but wondering about the API. If so, then where did you set auto-adjust column width in the UI?
Cheers,
Adam:
I know very little about iLogic and nothing about the API. I am trying to find away to have the parts list autoadjust depending on the contents of the cell.
I was just wondering if you were aware of a way, that I'm missing, to set the column width through the User Interface to auto-adjust to content. I haven't found anything like that in the API either, so probably it's not possible. 😞
is there a way to change the width by iLogic?
For Each oCustomTable In oSheet.CustomTables If oCustomTable.TableSource=77058 Then 'kBendTableSource For Each oColumn In oCustomTable.Columns oColumn.Title=Replace(oColumn.Title,"BEND","") 'MessageBox.Show(oColumn.Width,oColumn.Title) 'oColumn.Width=1.5 'why it does not work... 'oColumn.Width=InputBox("Prompt", "Title", oColumn.Width) Next End If Next
None of two comented lines does not change the column width. Am I missing something obvious or it's just not possible?
thanks
Jozef
