I find that the Invetor.ExpressionList is available when using VBA but not when using VB and the Inventor Interop. Is this by design? If not is there a way I can get it to show up in VB?
Scott A. McCoy
West-Mark Mfg.
Solved by MjDeck. Go to Solution.
It should be available. What version of Inventor are you using? What version of Visual Studio?
I am using Inventor 2012, Win 7 64-bit, Visual Studio 2008 Express & Inventor Interop version 14.0.0.0
Scott A. McCoy
Inventor Interop version 14.0.0.0 is for Inventor 2010. ExpressionList was added in 2011. You should delete that reference and instead reference version 16.0.0.0 (for Inventor 2012). On a 64-bit system, you may have to browse to the Interop dll in
C:\Program Files\Autodesk\Inventor 2012\Bin\Public Assemblies
