Parameters and Properties
10 REPLIES 10
Message 1 of 11
394 Views, 10 Replies
Hi all
2 Quick questions on parameters and properties:
1. Is it possible to change the value of a custom property? I found User
parameters, Table parameters and Model parameters, but nothing on Custom
Properties.
2. Why, when I access a user parameter (for example called "comp") using
oParamsUser.Item("comp").Value
the value that is returned is 10x smaller than it should be?
Is this the cm - mm issue? The parameter is defined as mm.
______________
Rui
www.cadmais.pt
10 REPLIES 10
Message 2 of 11
avbuiten
A1: look at post titled: "Inventor/VB(A)/Class to handle Document Properties"
A2: Values are in CM, Expressions might be in MM
Message 3 of 11
Let me see if I get this: even though I input a parameter in the model as
mm, the value reported by VBA will always be in cm?
Is there a table with this correspondence, ie: length dimensions are in cm,
mass in kg, etc?
______________
Rui
www.cadmais.pt
"avbuiten" wrote in message
news:f1a16ec.0@WebX.maYIadrTaRb...
Properties"
Message 4 of 11
avbuiten
See Inventor Help, search for "Edit box reference"
These are expressions you can use from within the UI.
Internally length values are always stored in CM.
Don't know about other measurements, but i's fairly easy to explore the bbject structures to see how and what they are stored.
Message 5 of 11
______________
Rui
www.cadmais.pt
news:f1a16ec.2@WebX.maYIadrTaRb...
Message 6 of 11
I tried getting a custom parameter from a part using:
Dim oProps As PropertySets
Set oProps = oPeça.PropertySets
Dim oParam As PropertySet
Set oParam = oProps.Item("dims")
but i get the following error:
"ActiveX component can't create object"
Any ideas?
______________
Rui
www.cadmais.pt
"Rui" wrote in message
news:690AF04ABB14A00F438C7BAE025BCBE3@in.WebX.maYIadrTaRb...
> Hi all
> Properties.
> Thanks
> ______________
> Rui
> www.cadmais.pt
Message 7 of 11
paulschuepbach
Anton, Rui,
well, this is not generally CM - in sheetmetal it's MM and I think in threades holes the drill-diameter is im MM too (any confusion with all the rest...). Have a look at the UnitsOfMeasure Property. With that you can 'convert' any input to the acatual units, so you go around the 'factor 10' problem. Hope this helps.
Best,
Paul
Message 8 of 11
avbuiten
OOPS. Sorry for my mistake. Hope not too many holes are bored too small.
Anton
Message 9 of 11
avbuiten
I think oParam variable is not of type PropertySet but Property. You may use type Object as well although i wouldn't do that.
See for more details the topic "Get Part Enabled Information"
Message 10 of 11
That was it.
I used the following code to set the value of custom property "dims" to the
value of a variable tDims:
Dim oUserDefParam As PropertySet
Set oUserDefParam = oProps.Item("User Defined Properties")
Set oParam = oUserDefParam.Item("dims")
oParam.Value = tDims
Thanks for the imput. Now to see about the units of measurement.......or
maybe I'll leave the factor 10, it's Friday and it's working....
______________
Rui
www.cadmais.pt
news:f1a16ec.7@WebX.maYIadrTaRb...
Message 11 of 11
Paul,
I think all length units are handled as CM
regardless of the type of feature or part.
Inventor's internal units are based on the cgrs
system (cm, gram, radian, second).
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Anton,
Rui,
Best,
Paul
