I just recently discovered how to change part parameter dimensions from decimal to fractional using the "Custom Property Format" window inside the parameters window, so the numbers appear as fractions in the BOM in lieu of decimals. Is there a way to set this as the standard instead of editing each part manually? Thanks.
