Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Paper Sizes and Apprentice Server Problem
3 REPLIES 3
422 Views, 3 Replies
I am having problems printing to drawing sizes other then A Size (Letter).
I have scanned through the messages in this Newsgroup and tried
everything that I have found, including making sure that I set the
properties in a specific order.
No matter what size I specify, the printer spits out the drawing on an A
Size piece of paper. Anybody have any suggestions?
Here is my code:
Private objApprenticeServerApp As New ApprenticeServerComponent
Private Sub PlotInventorDrawing(strDwgPath As String, strPlotSize As
String, strPlotter As String)
' Open a document.
Dim odoc As ApprenticeServerDocument
Set odoc = objApprenticeServerApp.Open(strDwgPath)
Dim oPrintMgr As ApprenticeDrawingPrintManager
Set oPrintMgr = odoc.PrintManager
' Set printer
oPrintMgr.Printer = strPlotter
' Set the paper size.
Select Case strPlotSize
Case "A"
oPrintMgr.PaperSize = kPaperSizeLetter
Case "B"
oPrintMgr.PaperSize = kPaperSize11x17
Case "C"
oPrintMgr.PaperSize = kPaperSizeCSheet
Case "D"
oPrintMgr.PaperSize = kPaperSizeDSheet
Case "E"
oPrintMgr.PaperSize = kPaperSizeESheet
End Select
' Set to print full scale.
oPrintMgr.ScaleMode = kPrintBestFitScale
' Set to print using portrait orientation.
oPrintMgr.Orientation = kLandscapeOrientation
' Set to print in color.
oPrintMgr.ColorMode = kPrintColorPalette
' Print
oPrintMgr.SubmitPrint
End Sub
Scott Maier
Programmer/Analyst
SPX Process Equipment - Lightnin
3 REPLIES 3
Hi Scott,
I haven't been able to reproduce the problem. I tried your code and it seems
to work fine for me. You might have to narrow down the problem some more (I
would start with taking out the line of code that sets the printer). What
Inventor version are you on?
Sanjay-
"Scott Maier" wrote in message
news:4852343@discussion.autodesk.com...
Here is my code:
' Open a document.
' Set printer
Case "A"
Case "B"
Case "C"
Case "D"
Case "E"
End Select
' Print
End Sub
Scott Maier
Programmer/Analyst
If it's like the DWF writer, you must set the printer driver to the largest
possible size, then you can print everything that's smaller. I had a similar
problem when printing using the Autodesk DWF writer and found that no matter
what I told IV to print it would come out A size. Changing the DWF writer to
E size allowed me specify whatever size I wanted. It's worth a try ...
Joe
Here is my code:
' Open a document.
' Set printer
Case "A"
Case "B"
Case "C"
Case "D"
Case "E"
End Select
' Print
End Sub
Scott Maier
Programmer/Analyst
sellis
Setting 11x17 paper size in printer defaults fixed a printing problem I was having wiht my VB.NET addin and a KONICA MINOLTA C364 printer.
