Hi guys,
I have just realised that the oView.Label.FormattedText is not working anymore. It was working before "Hot-Fix INV19102" and now trows an error.
Try to change the view label like with this code from Curtis:
Dim oSSet As SelectSet = ThisDoc.Document.SelectSet If oSSet.count = 0 Then MessageBox.Show("You must select a drawing view first", "iLogic") Exit Sub End If 'Reference to the drawing view from the 1st selected object Dim oView As DrawingView = trycast(oSSet.item(1), DrawingView) If oView IsNot Nothing Then oView.ShowLabel = True 'format the model iproperties oDescription = "<StyleOverride Underline='True'><Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>" oPartNumber = "<StyleOverride Underline='True'> - Mk <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>" oStringMass = "<Br/><StyleOverride Underline='False' FontSize='0.35'>EST UNIT MASS = <PhysicalProperty PhysicalPropertyID='72449' Precision='2'>MASS</PhysicalProperty></StyleOverride>" oStringScale = "<Br/><StyleOverride FontSize='0.3'>(Scale <DrawingViewScale/>)</StyleOverride>" 'add to the view label oView.Label.FormattedText = oDescription & oPartNumber & oStringMass & oStringScale Else MessageBox.Show("The selected object is not a drawing view", "iLogic") End If
It all goes well till seetting the view label.
Thanks.
Solved by salariua. Go to Solution.
Face slap.
Nevermind this, I was having overlapping views and using rectangular selection didn't help as well.
