Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Orientation Angle of Occurrence
Hello.
Does anyone know how get the orientation angle of an occurrence using VBA?
Please see attached file for reference.
Thanks in advance.
ok, first I hope you know that retriving the euler angles not always give the result you expect, but this is no error, its just the way the angles work..
here are some code to retrieve the angles:
'some globals:
Global PI As Double
Global RadToDeg As Double
Global trans() As Double
' a few helper functions...
 Private Function Atan2(y, x As Double)
' returned value is in radians
    If x > 0 Then
        Atan2 = VBA.Atn(y / x)
    ElseIf (x < 0 And y >= 0) Then
        Atan2 = VBA.Atn(y / x) + PI
    ElseIf (x < 0 And y < 0) Then
        Atan2 = VBA.Atn(y / x) - PI
    ElseIf (x = 0 And y > 0) Then
        Atan2 = PI / 2
    ElseIf (x = 0 And y < 0) Then
        Atan2 = -PI / 2
    ElseIf (x = 0 And y = 0) Then
        Atan2 = 0
End Function
Function ArcSin(x As Double) As Double
    ArcSin = VBA.Atn(x / VBA.Sqr(-x * x + 1))
End Function
Function ArcCos(x As Double) As Double
    ArcCos = VBA.Atn(-x / VBA.Sqr(-x * x + 1)) + 2 * VBA.Atn(1)
End Function
Private Function EulerThree()
    If (trans(8) <> 1 And trans(8) <> -1) Then
        EulerThree = Atan2(trans(4) / VBA.Cos(ArcSin(trans(8))), trans(0) / VBA.Cos(ArcSin(trans(8))))
    Else
        EulerThree = 0
End Function
Private Function EulerTwo()
        EulerTwo = -ArcSin(trans(8))
    ElseIf (trans(8) = -1) Then
        EulerTwo = PI / 2
    Else
        EulerTwo = -PI / 2
End Function
Private Function EulerOne()
        EulerOne = Atan2(trans(9) / VBA.Cos(ArcSin(trans(8))), trans(10) / VBA.Cos(ArcSin(trans(8))))
        EulerOne = Atan2(trans(1), trans(2))
    Else
        EulerOne = Atan2(-trans(1), -trans(2))
End Function
Private Function EulerAngles()
    'convert from radian to degree
    Dim eulers(2) As Double
    eulers(0) = EulerOne() * RadToDeg
    eulers(1) = EulerTwo() * RadToDeg
    eulers(2) = EulerThree() * RadToDeg
    EulerAngles = eulers
End Function
'finally the function that retrieves the rotations:
Sub GetAngleOfOccurence()
    Dim oDoc As Inventor.Document
    Set oDoc = ThisApplication.ActiveDocument
    Select Case oDoc.DocumentType
        Case kAssemblyDocumentObject
            ' Set a reference to the first occurence in the assembly
            Dim oOcc1 As ComponentOccurrence
            Set oOcc1 = oDoc.ComponentDefinition.Occurrences.Item(1)
            Dim oMatrix As Matrix
            ' Get the transform from the occurrence
            Set oMatrix = oOcc1.Transformation
            ' insert point is in the matrix:
            Call oMatrix.GetMatrixData(trans) ' get the matrix as an Array
            'test if we get an array..
            If (Not IsNull(trans) And IsArray(trans)) Then
                Debug.Print
                Debug.Print "Insert point in centimeter X, Y, Z=: "; trans(3); trans(7); trans(11)
            ' invert matrix to get the parts transform in the assembly's coordinates
            Call oMatrix.Invert
            ' be aware that retrieving the eulers from the matrix may not produce the result you would expect.
            ' you should keep to the matrix if you can.
                PI = 3.14159265358979
                RadToDeg = 180 / PI
                Dim result() As Double
                result = EulerAngles
                Debug.Print "Euler 1=: "; result(0)
                Debug.Print "Euler 2=: "; result(1)
                Debug.Print "Euler 3=: "; result(2)
                Debug.Print
        End Select
End Sub
Thank you so much. It's a great help!
