Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ordinate dimension problem
6 REPLIES 6
GeorgK
609 Views, 6 Replies
Hello together,
I would like to improve the ordinate dimensioning in Inventor. How could I add the dimension in a quicker way?
Process:
1. Pick ordinate dimension
2. choose the  view
3. choose the  zero point
4. select the line to dimension
5. click next
6. position the dimension
7. click ok
8. repeat from 1 for each dimension.
Add one:
2. choose the  view
3. select the line to dimension
4. click next
5. position the dimension
6. click ok
7. repeat from 1 for each dimension.
Process wish:
2. choose the  view
8. repeat from 1 for each dimension til ESC
Thank you very much
Georg
6 REPLIES 6
GeorgK
in reply to: GeorgK
I found a sample. How could I select the points where the dimensions are placed?
'    Create ordinate dimension API Sample
	'Description
	'This sample demonstrates the creation of ordinate dimensions in a drawing document.
	'Before running this sample, select a linear drawing curve on the active drawing document.
	Public Sub CreateOrdinateDimensions()
		' Set a reference to the drawing document.
		' This assumes a drawing document is active.
		Dim oDrawDoc As DrawingDocument = DirectCast(ThisApplication.ActiveDocument, DrawingDocument)
		' Set a reference to the active sheet.
		Dim oActiveSheet As Sheet = DirectCast(oDrawDoc.ActiveSheet, Sheet)
		' Set a reference to the drawing curve segment.
		' This assumes that a linear drawing curve is selected.
		Dim oDrawingCurveSegment As DrawingCurveSegment = DirectCast(oDrawDoc.SelectSet(1), DrawingCurveSegment)
		' Set a reference to the drawing curve.
		Dim oDrawingCurve As DrawingCurve = Nothing
		oDrawingCurve = oDrawingCurveSegment.Parent
		If Not (oDrawingCurve.CurveType = CurveTypeEnum.kLineSegmentCurve) Then
			MessageBox.Show("A linear curve should be selected for this sample.")
			Return
		' Create point intents to anchor the dimension to.
		Dim oDimIntent1 As GeometryIntent = Nothing
		oDimIntent1 = oActiveSheet.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent)
		Dim oDimIntent2 As GeometryIntent = Nothing
		oDimIntent2 = oActiveSheet.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent)
		' Set a reference to the view to which the curve belongs.
		Dim oDrawingView As DrawingView = Nothing
		oDrawingView = oDrawingCurve.Parent
		' If origin indicator has not been already created, create it first.
		If Not oDrawingView.HasOriginIndicator Then
			' The indicator will be located at the start point of the selected curve.
			oDrawingView.CreateOriginIndicator(oDimIntent1)
		' Set a reference to the ordinate dimensions collection.
		Dim oOrdinateDimensions As OrdinateDimensions = Nothing
		oOrdinateDimensions = oActiveSheet.DrawingDimensions.OrdinateDimensions
		' Create the x-axis vector
		Dim oXAxis As Vector2d = Nothing
		oXAxis = ThisApplication.TransientGeometry.CreateVector2d(1, 0)
		Dim oCurveVector As Vector2d = Nothing
		oCurveVector = oDrawingCurve.StartPoint.VectorTo(oDrawingCurve.EndPoint)
		Dim oTextOrigin1 As Point2d = Nothing
		Dim oTextOrigin2 As Point2d = Nothing
		Dim DimType As DimensionTypeEnum = Nothing
		If oCurveVector.IsParallelTo(oXAxis) Then
			' Selected curve is horizontal
			DimType = DimensionTypeEnum.kVerticalDimensionType
			' Set the text points for the 2 dimensions.
			oTextOrigin1 = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingCurve.StartPoint.X, oDrawingView.Top + 5)
			oTextOrigin2 = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingCurve.EndPoint.X, oDrawingView.Top + 5)
		Else
			' Selected curve is vertical or at an angle.
			DimType = DimensionTypeEnum.kHorizontalDimensionType
			oTextOrigin1 = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left - 5, oDrawingCurve.StartPoint.Y)
			oTextOrigin2 = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left - 5, oDrawingCurve.EndPoint.Y)
		' Create the first ordinate dimension.
		Dim oOrdinateDimension1 As OrdinateDimension = Nothing
		oOrdinateDimension1 = oOrdinateDimensions.Add(oDimIntent1, oTextOrigin1, DimType)
		' Create the second ordinate dimension.
		Dim oOrdinateDimension2 As OrdinateDimension = Nothing
		oOrdinateDimension2 = oOrdinateDimensions.Add(oDimIntent2, oTextOrigin2, DimType)
	End Sub
wayne.brill
in reply to: GeorgK
You could use a mouse event to get a point from the user. This DevBlog post has an example of using MouseEvents.
http://adndevblog.typepad.com/manufacturing/2013/02/pick-a-point.html
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
GeorgK
in reply to: wayne.brill
Hi Wayne,
please could you help me with that problem?
Thank you Georg
GeorgK
in reply to: GeorgK
Could someone help me with that problem? Thanks Georg
philippe.leefsma
in reply to: GeorgK
Hi Georg,
What is the "problem" exactly? Was the suggestion from Wayne helpful?
You would need to implement a command that prompt the user to select a drawing curve, at the same time, you could use mouse events to check the exact position the user clicked and determine what is the point on the selected curve which is the closest.
See "Sheet.CreateGeometryIntent" in the help files, there are many samples provided along.
Hope that helps,
Philippe.
Philippe Leefsma
GeorgK
in reply to: philippe.leefsma
Hi Philippe,
I could not get it to work to pick the use of the mouse events to check the exact position the user clicked and determine what is the point on the selected curve which is the closest.
Georg
