How can i open an existing assembly or part file (stored on a local drive) through the API? It should be possible, but i cannot find the required method calls in the API-documentation.
Win7 64bit, Autodesk Inventor 2011
Solved by Mike.Wohletz. Go to Solution.
In VBA
Public Sub openitem() Dim strPath As String strPath = "c:\jobs\widget.ipt" Dim invDoc As Document Set invDoc = ThisApplication.Documents.Open(strPath, True) End Sub
