Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Open .iam in project folder ilogic?
21 REPLIES 21
Message 1 of 22
DeerSpotter
1455 Views, 21 Replies
instead of this can i actually have it look at current project folder?
'these links will need to be updated for current physical location everytime folder is moved or renamed.
Public Sub Main()
If Component.IsActive("DETAIL B 26310C:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C.iam", True)
End If
If Component.IsActive("DETAIL B 26310C REV1:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C REV1.iam", True)
End If
If Component.IsActive("DETAIL B 26310C REV2:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C REV2.iam", True)
End If
 End Sub
 Any help would help out alot.... thanks!
Image and video hosting by TinyPic
See My LinkedIn Profile
21 REPLIES 21
Message 21 of 22
DeerSpotter
in reply to: rjay75
even this fails arghhhh
shell2 = Component.Visible(ThisDoc.FileName(False)) 'without extension)
Component.InventorComponent(shell2).ExitEdit(kExitToPrevious)
 Still it cant find the document (im running the rule inside the component im editing)
Message 22 of 22
rjay75
in reply to: DeerSpotter
That won't work because you can't access a component occurrence while editing the component. It can only be accessed or referenced from the assembly.
Off hand don't know of a way to easily exit the editing document with out any references to the parent assembly.
Also the filename and the component names may look similar but they are two different names and don't match. So you can't use one to find another. If you want to use a consistent name, rename your components and use that name instead. Even if you change the underlying component document the component names stay the same.
