Occurrence material color change
PACDrafting
PACDrafting
Hi
How do I change the a part material render style within an assembly?
I have tried this below. It changes the name but doesn't update the render style.
Sub Material()
Dim oassy As AssemblyDocument
Set oassy = ThisApplication.ActiveDocument
Dim ocompdef As AssemblyComponentDefinition
Set ocompdef = oassy.ComponentDefinition
Dim ooccurr As ComponentOccurrences
Set ooccurr = ocompdef.Occurrences
Dim opartdef As ComponentDefinition
Set opartdef = ooccurr.Item(11).Definition
opartdef.Material.RenderStyle.Name = "Red"
End Sub
xiaoyan.qi
hi
you can try to change the last statement as below
   opartdef.Material.RenderStyle = opartdef.Document.RenderStyles.Item("Red")
   ' the original statement  opartdef.Material.RenderStyle.Name = "Red"
Let me know if it works
Mick
PACDrafting
Hi Mick,  works fine.
