Using Inv 2013. In the rectangular pattern, you can obtain the parameter objects driving that pattern. This is useful because you can rename them for later use. Is there a way to obtain the parameter object from a constraint object? When creating constraints, it would be nice to rename the driving parameters for later use. Or,
Eric
Which constraints are you talking about? You need to be a bit more specific if you are looking for a specific answer... Take a look at the relevant object properties in the API Help Files:
For example
MateConstraint.Offset Property: returns the Parameter object controlling the offset between the occurrences
TwoPointDistanceDimConstraint.Parameter Property: return also the parameter controlling the distance of that constraint
And so on ...
I hope it helps,
Philippe.
Well then you got your answer: each assembly constraint object should expose a property that returns the parameter(s) controling the constraint.
Philippe.
