Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Non-Defined (Dynamic) Arrays in iLogic
1 REPLY 1
MegaJerk
2139 Views, 1 Reply
Is there a way to declare a non-bound array (dynamic array?) in iLogic?
There are examples of set bounds array:
MyDoubleValues = New Double(){1.2,2.2,3.3}
But doing something like:
Dim MyDoubleValues() As Double  ---Or---  MyDoubleValues = New Double()
Results in an error. On the other hand, the following totally works:
Dim MyDoubleValues(1) As Double
Which creates an array with a Ubound of 2
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
1 REPLY 1
MegaJerk
in reply to: MegaJerk
Alright, I sort of solved my own problem. The code below is a test showing that you can make a single slot defined array, make it grow based on user inputs, sort it, and make it shrink to remove any duplicate entries. It's not pretty, but I never claimed that I was a coding genius 😉
What it does: Produces an input box asking for numerical inputs. When you are done hit cancel or simply hit enter (leaving the input blank), and you will be asked to confirm. Once you confirm, the array will be sorted from lowest to highest and returned to you via a message box.
The intention of this test was to figure out a way to capture a series of user inputs in a dynamic (on the fly sort of) way, to allow for the later combination of the user array and any predefined array (or series of numbers) that existed in my Inventor assembly as calculated parameters.
Oh one last note : This is sorting using the Bubble Sort method.
Dim holder As Object
Dim fakeArray(0) As String
Dim i As Integer
Dim holderList As String
i = 0
holder = InputBox("Please Enter Your Channel Possitions", "Number Muncher", "")
If IsNumeric(holder) = True Then
fakeArray(i) = holder
While holder <> ""
holderList = Join(fakeArray,",")
holder = InputBox("Please Enter Your Next Value" & vbCrLf &" The Current Values are : " & holderList, "Number Muncher", "") '
i = i+1
ReDim Preserve fakeArray(i)
Else
ButtonValueTest=MsgBox("Would You Like To Stop Entering Values?", vbYesNo,"Question Time!")
If ButtonValueTest = vbYes Then
'MessageBox.Show("You pressed : Yes","Results")
Exit While
Else
'MessageBox.Show("You pressed : No","Results")
holder = "1"
End While
'MessageBox.Show(UBound(fakeArray),"")
Dim ArraySize As Integer
ArraySize = UBound(fakeArray)
Dim slot1, slot2, swapped As Double
Dim APos As Integer
Dim IdentCount As Integer
swapped = 2
If ArraySize < 1Then
MessageBox.Show("Array has been sorted: " & holderList, "")
Else If ArraySize > 0 And ArraySize < 2 Then
slot1 = fakeArray(0)
slot2 = fakeArray(1)
If slot1 < slot2 Then
MessageBox.Show("Array has been sorted: " & holderList,"")
Else If slot1 > slot2 Then
fakeArray(0) = slot2
fakeArray(1) = slot1
Else If slot1 = slot2 Then
'Remove(fakeArray(1))
ReDim Preserve fakeArray(0)
MessageBox.Show("An Array has been changed to: " & holderList,"")
Else If ArraySize > 1 Then
'MessageBox.Show("Array Larger Than 1", "")
While swapped > 1
swapped = 1
For APos = 1 To UBound(fakeArray) Step 1
'MessageBox.Show("Looping through Array","")
slot1 = fakeArray(Apos-1)
slot2 = fakeArray(Apos)
If slot2 < slot1 Then
fakeArray(Apos-1) = slot2
fakeArray(Apos) = slot1
swapped = 2
Else If slot2 = slot1 Then
For IdentCount = APos To UBound(fakeArray) Step 1
'MessageBox.Show("Upper Bound: " & UBound(fakeArray) & " And Ident " & IdentCount, "")
If IdentCount = UBound(fakeArray) Then
ReDim Preserve fakeArray(IdentCount - 1)
Apos = 1
'MessageBox.Show("New UBound: " & UBound(fakeArray),"")
Exit For
fakeArray(IdentCount) = fakeArray(IdentCount + 1)
Next
swapped = 2
'MessageBox.Show("APos : " & APos,"")
If APos >= UBound(fakeArray)
Exit For
Next
If swapped <> 2 Then
swapped = 0
End While
MessageBox.Show("Array has been sorted down to: " & holderList,"")
GitHub
