Hi All
Does anyone know why there is no BIM Tab in Inventor 2015.
We have 6 pc's all installed at the same time and one has no BIM tab in the ribbon.
We tried looking through the custom commands and the command "check revit features" is not there either or anything related to BIM.
We have repaired the install and re-installed and it still does not appear.
Cheers
Yes they are loaded, I even took the .dll files from a working pc and copied them in and that didnt work either.
Its a bit of a mystery.
mailbox,
Can you please use the Inventor Reset Utility on this machine as the user that is having this issue:
It will remove all of the Inventor information from the user's Windows Profile and then when you start Inventor it will repopulate his profile from scratch.
Thank you.
