Does Autodesk have a place for new ideas for Inventor? I have written a macro for expression building that I believe should really be intergrated into Inventor itself. This macro lets you use the materials and dimensions to build quick expressions and puts them into the part number and stock number iProperties. I believe the only way previously was to do it through the iProperties box, unless you purchased and add-in program from a third party. I felt this should have been much easier to accomplish so I built it into my "ever growing" .ivb file for work. So if someone could pint me in the right direction, I would appreciate it..
Solved by Curtis_Waguespack. Go to Solution.
Hi waynefisher,
You can share your ideas about how to improve Inventor with the Development Team using this link:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I hope this helps.
Curtis
