In my skelton modelling assemblies, for all possible parts and assemblies, I assign X, Y and Z offsets zero and then ground - from within Occurance tab of iProperties tool pallet. I like to do the same with an iLogic for which I request help.
Autodesk Inventor - 2014
Thanks.
Best Regards.
Solved by RoyWickrama_RWEI. Go to Solution.
Solved by adam.nagy. Go to Solution.
If I understand you correctly then this should help:
http://adndevblog.typepad.com/manufacturing/2014/10/set-the-offset-of-components-to-zero-and-ground-...
Cheers,
Hi Adam Nagi,
Dim doc As AssemblyDocument
doc = ThisApplication.ActiveDocument
Dim tr As TransientGeometry
tr = ThisApplication.TransientGeometry
Dim occ As ComponentOccurrence
For Each occ In doc.ComponentDefinition.Occurrences
' If it's suppressed we cannot do
' anything with it
If Not occ.Suppressed Then
Call occ.SetTransformWithoutConstraints(tr.CreateMatrix())
occ.Grounded = True
End If
Next
Shown above is the code (as is) per your guidance. Thanks a lot. That is 100% what I need currently. It is working so nice and is definitely a great help on my huge-assembly skeleton modelling.
Best Regads;
Roy Wickrama
Autodesk Inventor - 2014 & Vault Basic 2014
