Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Need to assign X, Y, X offset (0.000) and apply ground constraint
2 REPLIES 2
RoyWickrama_RWEI
476 Views, 2 Replies
In my skelton modelling assemblies, for all possible parts and assemblies, I assign X, Y and Z offsets zero and then ground - from within Occurance tab of iProperties tool pallet. I like to do the same with an iLogic for which I request help.
Autodesk Inventor - 2014
Thanks.
Best Regards.
2 REPLIES 2
If I understand you correctly then this should help:
http://adndevblog.typepad.com/manufacturing/2014/10/set-the-offset-of-components-to-zero-and-ground-...
Cheers,
Adam Nagy
Autodesk Platform Services
Hi Adam Nagi,
Dim doc As AssemblyDocument
doc = ThisApplication.ActiveDocument
Dim tr As TransientGeometry
tr = ThisApplication.TransientGeometry
Dim occ As ComponentOccurrence
For Each occ In doc.ComponentDefinition.Occurrences
    ' If it's suppressed we cannot do
    ' anything with it
    If Not occ.Suppressed Then
        Call occ.SetTransformWithoutConstraints(tr.CreateMatrix())
        occ.Grounded = True
    End If
Next
Shown above is the code (as is) per your guidance. Thanks a lot. That is 100% what I need currently. It is working so nice and is definitely a great help on my huge-assembly skeleton modelling.
Best Regads;
Roy Wickrama
Autodesk Inventor - 2014 & Vault Basic 2014
