So the problem I am having is that I have an ipart that allows me to narrow down my available options with "keyed" elements, yet I can not figure out how to recreate the "keyed" options within the iLogic rules/Paramaters.
Example: Lets say I have a part that is a certain diameter and based on it's diameter the availbel length and material options would apply, and those options would defer from dia. to dia. (just like choosing a bolt from Content Center).
I have an excel sheet controling the availbe options and I have linked it to the part and wrote several rules to pull out the data. The problem I'm running into is that when I choose a diameter it shows the enitre "column" of the spreadsheet instead of just teh "like" sizes, the length option does the same as well as the material.
See attached pics (the first pic is the ipart that works flawlessly), the others are the results I'm getting
My VAR told me to write out what I was trying to do, but I keep getting syntax errors, so I'm not sure what is wrong, but here's what I'm trying to do:
If Type = Exhaust, then Material is Aluminzed or Stainless
If Type = Intake than Material = Aluminum
If Material = Alumunized, then avaiable sizes are: (2, 2.5, 2.75, 3, 3.5, 4, 5, 6)
If Material = Stainless, then avaiable sizes are: (3, 3.5, 4, 5)
If Material = Aluminum than avaiable sizes are: (3, 3.5, 4, 5, 5.5, 6, 7, 😎
I'm just not sure how to make iLogic have "steps" in the choice process that narrow avaibale options as choices are made..
Hi FritscheCAD
I wrote a blog on this topic (changing available options on a multi-value list) -
Does that help?
Luke
This looks like it will work, Thank you!
is there anyway to have the available parameters determined frorm inside the excel sheet instead of typing them in, some of these are about 30 options each for 4-5 different options..??
Its pretty straightforward to do. This standard iLogic snippet should get you started:
MultiValue.List("d0") = GoExcel.CellValues("filename.xls", "Sheet1", "A2", "A10")
